Y-pipe = lower MPG
Y-pipe = lower MPG
Since I've added my budget y-pipe I've dropped my average mpg from around 22 to 19. My driving habits haven't changed. This doesn't seem to fall in line with any other intake/ exhaust mod I've ever done on a car, or for that matter, any one else has either. Any thoughts? Also, with y-pipe and cat, is it really worth doing b-pipe and muffler? Looking for input from those that have tried. Thanks..
Originally Posted by 99se5speed
Wow...i'm totally in the same situation! I really hope you guys can enlighten us!!!
I didn't really pay attention to my before and after gas milage with the y-pipe. I get pretty crappy gas milage but that's cause I have a heavy foot. When I drove from NY to FL on i-95 with the cruise control set, I made close to 475 miles per tank driving straight through only stopping for gas. Wonder what it would have been with the stock y-pipe. I get good highway milage but crappy city milage but that's cause I have a heavy foot.
Damn now idk if i want to put on the y-pipe and high flow cat i just got. I have a new o2 just in case something does happen to the stock ones. I'm going to the dealership today to pickup my order of all OEM gaskets so that i have no leaks because the crap the budget sends with the y-pipe is definitely not going onto my car!!!
I also wanted to know...can i rest my ecu after i install the pipe and cat? Will this help it get used to the setup so that the air/fuel ratio will improve? I was told the best way to reset the ecu is to take your battery terminals and smack them together a few times to reset the ecu (I'm very skeptical of this). Any info on this? Thanks.
something with your setup is OFF....I know that I get better mileage as well as response since putting on my warpspeed...but I also have a full cat back (Greddy SP1) but all in all...a mod that I love and would definitely recommend for anyone that wants to unlock the potential of the maxima
As a general rule, more power=more gas consumption. Im sure that a more free flowing exhaust increases a lil gas mileage but the actual increase in power output is a larger sum. Also, keep in mind its the summer now and you are blasting your a/c and the car in general is choking to death with all the humidity. I would def expect a small drop in gas mileage with a y-pipe.
I think that's wrong. Most exhaust mods lessen the resistance, making it easier for the engine to pump out the exhaust, which allows the engine to be more efficient. That is FREE power.
So theoretically there should be a slight increase in gas mileage with a Y-pipe, headers, test pipe, B-pipe, etc. However, if you tend to drive a lot harder because of the newfound power, then obviously your mileage will go down.
Check for exhaust leaks and check all your O2 sensors, which are known to seriously hurt gas mileage when malfunctioning. Might as well check for a knock sensor code while you're at it.
No exhaust leaks (at least large enough to be detected). The only code i get is downstream sensor, which will not affect a/f mix or in effect gas mileage/performance unless upstream sensor malfunctioning. Tests were done within a few weeks of each other, so temp diff spring vs fall had nothing to do with it. ? !
What type of intake do you have? I would suspect a problem with your set up or a sensor that is not working properly, dirty MAF or broken o2 sensor. I had a cone intake and the y-pipe and got better gas mileage.
Good luck
Good luck
I too saw a drop after my install 6 yrs ago. My mpg dropped from 23mpg to 21.5 and the only other change was the addition of a b-pipe. Both were 10 tank averages same exact time of the year with no MIL problems.
MaxLvr21
10-17-2015 12:11 PM
DC_Juggernaut
09-28-2015 04:07 PM
