View Poll Results: At what RPMs do you shift
less than 1500 - grandma
0.87%
1500-2500 - savin' gas
56
24.24%
2500-3500 - cruisin'
122
52.81%
3500-4500 - showing off
29
12.55%
4500-5500 - street racing
1.73%
I redline it everytime!! (being stupid)
18
7.79%
Voters: 231. You may not vote on this poll
poll: at what RPMs do you shift
Old 08-16-2006 | 03:11 PM
  #41
ethnic6's Avatar
I shift between 2000 to 3000rpms
Old 08-17-2006 | 08:37 AM
  #42
dutchmanx's Avatar
I don't....
My automatic transmission makes it for me at 2500
Old 08-20-2006 | 07:29 PM
  #43
Adri's Avatar
I shift between 2000-3500 rpms
Old 08-21-2006 | 10:12 AM
  #44
nismos14's Avatar
§è~® f®ÈÄk
1 -> 2 at 1500, 2 -> 3 at 1500, 3 -> 5 at 1500 and/or 3 -> 4 at 1500 and/or 4-6 at 1500.
Old 08-21-2006 | 08:05 PM
  #45
itsdaveonline's Avatar
I got an automatic but i always baby my car when its warm but has not been on long so i keep it around 2000, on normal operation i go no higher than 3500. But sometimes theres no traffic going onto the on ramp and im doing 5700ish but thats not often.
Old 08-22-2006 | 01:58 PM
  #46
97maximaman's Avatar
I guess i'll contribute even though its no difference. I shift at about 2500, but to be honest, who cares. Drive how you want to, i cant tell you how many people tell me you have to shift at 3k. BS, it really doesnt matter where you shift, just understand that higher shift = more wear, more heat, more gas. Only time i go to 4500 is on the on ramp to the highway, and even then i get to my speed and then i go straight to 5th.
Old 08-22-2006 | 02:26 PM
  #47
95_Maxima_5spd's Avatar
2500-3000 usually, unless i feel like hearing it growl a bit.....even then i shift at just over 5.....i havent even taken it it redline.
Old 08-22-2006 | 04:47 PM
  #48
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
depends .. in normal driving i'll let the auto shift at 2000-3000 rpms. If I have open road i'll take it to 4000-5000rpms
Old 08-22-2006 | 09:13 PM
  #49
I-30BLACKDEMON's Avatar
I have a 96 I-30T 5spd with VSLD. It also has POP, y-pipe, High flow cat and B-pipe/w high flow muffler. When driving for performace I usually shift at roughly 5,900 for best performance. Exept for on first and second because of the low ratios. All the dynos I've seen show horespower drops dramatically after 5,500. I've drove my friends I-30 with the MEVI, and in it you shift at redline with full power. It is great!!!
Old 08-23-2006 | 09:31 AM
  #50
nick_auto96's Avatar
Well my autotragic shifts for me and it shifts at 1400 rpm even if i floor it...LOL. If u don't believe, then check this vid: http://www.youtube.com/watch?v=ZmgNYrPIgls Actually my tach doesnt work well so I don't even know at what rpm it shifts!!!
Old 08-23-2006 | 10:47 AM
  #51
SSA-Don's Avatar
I don't bother shifting over 4500 or so RPMs. I had a '97 4cyl Accord EX (VTEC) 5 spd manual before this car. that car, you had to "drive it like you stole it" b/c the Variable Timing BS would open up more lifters for more air once you hit a high enough RPM to engage the VTEC.
But with no Variable Timing package on the V6 3000 maxima engine, I don't get the same "feel" of the VTEC accord. Not gonna say that the Accord was "faster", but the relative feel of the VTEC at higher RPMs definately made the car "feel" faster than the Maxima at higher RPMs.
Consequently, I'm not tempted to push the Max over 4000 RPMs. Just feels like i'm not gaining anything over that point.
I will also say that I'm in the middle of trying to rid the car of Check Engine codes. I was getting Knock Sensor and both front 02 sensors were bad. I replaced the front 02 sensors with new (used) sensors. I also put in a new (used) knock sensor that tested perfectly (550KOhms or something?) and now the car does seem to have more ***** under 3k rpms. But the Knock Sensor code is still popping up after 35 miles as well as the Rear 02 sensor now. So i'm gonna fill up with Premium Octane gas next time and change the rear 02 Sensor (the easier one) and see if I have any change of heart.
Old 08-23-2006 | 11:03 AM
  #52
RDroz's Avatar
A Maxima feels right being shifted at 2500-3000 rpm in traffic.
I hate drivers who shift early enough to have the car buck a couple of times on every upshift.
I don't have enough info on the Maxima, but my other car has an auto with "sport mode" that delays upshifts 5-600 rpm. On that car, it makes absolutely no difference to mileage.
Richard
Old 09-04-2006 | 12:19 PM
  #53
ComradeJew's Avatar
Saving gas style
It's 3.15 a gallon anywhere I go, and being how this thing takes 91 only (well recommended but seems like i am better off with it anyway), this makes me a sad panda
Old 09-04-2006 | 12:25 PM
  #54
nismos14's Avatar
§è~® f®ÈÄk
93 octane v-power was 2.83 this ewekend for me.
Old 09-04-2006 | 10:30 PM
  #55
UkiSash's Avatar
Depending on what im doing and how im feeling... mostly i shift around 3k more often before 2k to save gas.
Old 09-05-2006 | 05:18 PM
  #56
aventerav's Avatar
Originally Posted by Nissan 6
My car shifts by itself
Me too.
Old 10-06-2006 | 06:29 AM
  #57
coolhandmax's Avatar
the car shifts itself
Old 10-06-2006 | 06:36 AM
  #58
nismos14's Avatar
§è~® f®ÈÄk
Ghey autotragics
Old 10-11-2006 | 05:31 PM
  #59
gblkrt09
I shift at 2000-2500 daily but when im on it 6500
Old 10-11-2006 | 08:01 PM
  #60
Specialeded's Avatar
I like redline alot.....
Otherwise there are to many variables to estimate where I shift as it is dependant upon traffic. Also more over my cluthes current state says it hates shifting period.....5th gen on the way.
Old 10-11-2006 | 08:23 PM
  #61
frisballs17's Avatar
Originally Posted by momo80
From a standstill I Redline and pull out with 5th gear to save gas. I don't need to shift after that.
Depends on what kind of mood I'm in.
hows your clutch
Old 10-27-2006 | 09:54 AM
  #62
moogotzskillz2's Avatar
Depends but usually at 2.5-3K... but tend to redline a couple of times a day u can say(when lil civics try me) to make them look very bad ..
Old 10-27-2006 | 10:52 AM
  #63
heynow's Avatar
exactly the same here !
Old 10-27-2006 | 08:29 PM
  #64
hitman4's Avatar
shift low now and save gas.....or shift normaly at around 3 and save your engine from overloading later.
Old 10-29-2006 | 04:22 PM
  #65
skweaky's Avatar
everybody tha doesnt like how it feels fast 4, needs to try out the PR style CAI. wither that or the short ram. 98 SE still ggainin at 5
Old 11-24-2006 | 06:26 PM
  #66
Da_Shatterer's Avatar
Used to shift at around 2k until my roommate started complaining that I was shifting into 5th at 20mph (what an idiot). Ever since been shifting around 3k because it just feels better. Supreme gas is a &^*%$ for a poor college student like myself though.
Old 11-24-2006 | 06:34 PM
  #67
Apparition's Avatar
Ichiban King
9,000rpm everyday, I love my VTEC.
Old 11-24-2006 | 06:35 PM
  #68
nismos14's Avatar
§è~® f®ÈÄk
Who cares if your roommate b!tches, shift at 2k.
  #69
nismos14's Avatar
§è~® f®ÈÄk
Old 11-29-2006 | 09:34 AM
  #70
buzpuck11's Avatar
Usually between 2800 and 3100
Old 11-29-2006 | 10:26 AM
  #71
kemmo's Avatar
Usually around 2.5-3K to balance pleasure and gas mileage. However, lately have enjoyed pushing to 4K since prices at the pump have come down ;-)
Old 11-29-2006 | 08:51 PM
  #72
95 maxima se's Avatar
Silver Tooth S2K 9k FTMFW
usually around 2.5k-4.5k but sometimes
Unclejunebug
04-02-2016 06:42 AM
hayne
10-05-2015 12:53 PM
ef9
10-04-2015 09:43 AM
Need help
23
10-02-2015 09:56 AM
