front wheel studs
i take my rotors off, when i do it.......take the brake calipers, the caliper mount, and the rotors just slide off. i hammer the old ones out, and put a new one threw the hole, get some washers liek said above and put them on. Start tightening lugs nut and it will pull the stud into place.
get a breaker bar or a pipe, cause it takes alittle force
Originally Posted by Dubbya
Take the wheel off. Hammer out the old stud. Then put the new stud it, place washers on the front of it to act as a spacer, then use the lug nut to pull the stud into place.
What does the fact that you replaced them yesterday have anything to do with being unable to hurt the bearing?
You can cause the bearing to be prone to failure, or destroy it completely by directing extreme pressures at it sideways like that. They are not meant to withstand that type of force.
-Andrew
-Andrew
hey if u knew how they are build and how they are seated .... then u would know what im talking about.... plus u have the entire cvshaft bolted tothe hub with a 36mm nut... it aint going anywhere... but of course u dont wanna hit the damn thing side ways...
Your attempt to display knowledge has worked very well against you. If you knew how they were designed, and how they were designed to work, you would know they cannot withstand much side load.
I tell you what, why don't you google it?
Google wheel bearing side load
Google wheel bearing failure
The list goes on. Next time, before you post information, make sure you're correct.
-Andrew
Originally Posted by xxtavixx
Who said I didnt know how a rolling element bearing is built and seated? The fact there is a cv joint there has nothing to do with it. They_are_not designed to withstand load from that direction.
-Andrew
-Andrew
sorry but i had to
-Andrew
-Andrew
-Andrew
-Andrew
u cant hurt the bearing... i jus replced them yesterday...
ur a ..... learn to read posts noob...
Uhmm...as you were saying. Learn to read your own post. You changed your view on it after I corrected you. And not only at that, you made your statement two sided. You said
noob
-Andrew
[/QUOTE]Try to keep it to one story.
-Andrew[/QUOTE]
dude u are a moron arent u... if u learn to read correctly.. i said that ur not gonna hurt it by simply hitting the stud out... then i also added that u shouldnt hit it side ways...
-Andrew[/QUOTE]
-Andrew
-Andrew
That's the second time you've changed your story.
You didn't read those google things did you? YOU CAN HURT IT by hammering the studs out. Very common that it causes damage. The best way to avoid causing damage, if you do it by that method, is to hit hard once and get it out. Better yet, remove the stud and use a slide hammer.
Now, how about this, look in your Haynes manual. Or here's a free one:
http://autozone.com/repair_info.htm
Look up any car, and wheel stud removal. The website is down right now, but it will say do_no_hammer_the_studs_out_to_prevent_wheel_bearin g_damage or along those lines.
You have yet to provide any technical date or means to support yourself other than your word. Do you know why that is? Because you are wrong. Case closed. You've made yourself appear bad in one case, then another. I can't believe you wanted to come up with a rebuttle for a third time. Is it the simple fact that I'm a "noob"? Does that make you want to prove yourself superior?
Have a nice day. I hope you didn't destroy your wheel bearing while hammering your studs out, but at least you would have learned a valuable lesson, even if it wasn't "dont post what you dont know" or "dont try to school noobs" or even "people who use name calling as a rebuttle are not cool and look badly when completely destroyed by a noob with 38 posts, which is a mere fractoin of your 1567, at the time of original rebuttle"
Originally Posted by Apparition
an example of how post count doesnt always matter, sometimes its pure time and dedication haha..
take this b1tch fest to PMs or something. no sense making this thread a mess.
to the OP, there is a site that shows how to change a rear stud. pics and everything. i would assume it is very similar to the front. let me try to dig that up.
yep always better to rent than spend money on something that ur probably not gonna use for a long time..
15 minutes
it is very similar to the front, but the differance in doing it, is if you do nto have air tools to pull the stud through, the hub will spin on the back when you turn it with a socket wrech and breaker. The front the stays still. you need something to hold the hub still so it just does not turn when you crank the wrench.
ah, yea. makes sense.
BassAddictJ
08-04-2015 11:38 AM
