brake squeel
Old Aug 7, 2006 | 02:40 PM
nguyen925's Avatar
brake squeel
when i replaced my front brake pads, i didnt replace shims on my new pads. so could this be the source of the brake squeel i encounter when i slightly apply pressure to the brakes? i did bleed the brake system though but everything works fine. just need advice thanks.
Old Aug 7, 2006 | 02:59 PM
MIXXMAX's Avatar
If you didn't use the shims, did you apply the anti-squeal compound as well? Yeah, it's recommended to use the shims on the front brakes, but for the rears you can get away without the shims, just as long as you use the anti-squeal compound, you won't have any squealing noise. I would do the front brakes over again and put the shims on. I betcha the squeal will go away then. Good luck!
Old Aug 7, 2006 | 03:38 PM
chicken-n-rice's Avatar
Yeah, some brake lube on the back of the pads will help and also some on the caliper where the ends of the pads touch and the guide bolts.
Old Aug 8, 2006 | 12:55 PM
nguyen925's Avatar
i did add some of the brake lube, but my shims were gone so i couldnt really place them on the new pads. ill be sure to repalce those shims asap and see if theres any difference. thanks for the help.
Old Aug 8, 2006 | 01:35 PM
Sy0p's Avatar
my breaks make some weird noises too, simple way to fix it is to turn up the stereo.
Old Aug 8, 2006 | 01:43 PM
Kevlo911's Avatar
Kevlo for President
Your username looks familiar...
Old Aug 8, 2006 | 01:51 PM
Dubbya's Avatar
VK56 Inside
Shims > any goo on the back of the pads. Off topic but do you know any one selling any rims?
Old Aug 8, 2006 | 03:23 PM
GBAUER's Avatar
Old Aug 8, 2006 | 03:34 PM
crazy97's Avatar
I get it!
Uh, ohhhhh!
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
