Do you HAVE to change oil after Sea Foam?
Old Aug 17, 2006 | 12:58 PM
jim84's Avatar
Reason I ask is I just changed the oil yesterday & am only now learning about this Sea Foam thing. I don't really want to wait until my next oil change to give it a shot, but I also don't want to change the oil again so soon if by adding the Sea Foam tonight I absolutely NEED to do an oil change immediately.
Thoughts from the pros out there?
Thanks ...
Old Aug 17, 2006 | 01:00 PM
csb's Avatar
csb
I'm confused...isn't Sea Foam a FUEL additive? If so, then why would an oil change matter?
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
It can be used in oil as well. Short answer: YES.
Old Aug 17, 2006 | 01:28 PM
aznprid972's Avatar
You would only need to change your oil if you put SeaFoam into your crankcase. Why would you need to change your oil when it's being sucked in via vaccume line or gas tank?
Old Aug 17, 2006 | 01:32 PM
ajcool2's Avatar
Change your oil???? lol No you dont have to change your oil.
Old Aug 17, 2006 | 01:34 PM
scubasteve's Avatar
based on his original post it seems his intention is to use it via the crankcase. In which case you are always supposed to change the oil shortly after.
Old Aug 17, 2006 | 01:38 PM
kcryan's Avatar
If your putting it in your gas tank, no, but its a waste of seafoam anyway (try techron, gunmount regane, or Fuel Power)
If your putting it in your crankcase, yes about 15 min after you do it, but dont do this, use auto rx or lubecontrol in the crankcase, seafoam is no good.
If your sucking it down the intake, it is the best product for that, and yes you should change your oil after it, it sneaks past the piston rings and dirties up your oil, just wait until before your next change and then do it.
Old Aug 17, 2006 | 05:19 PM
jim84's Avatar
If I'm putting it into the vacuum line (which is what I'm planning to do), is that what you guys mean by crank case? So if I put it in the vacuum line, then yes, I need to get an oil change shortly after I do it? Just trying to clarify. Some of you seem to be using crank case & the vacuum line interchangeably, so I'm kinda confused.
Old Aug 17, 2006 | 05:45 PM
kcryan's Avatar
No, crankcase is where your oil is
Intake is different, but IMO still necisitates a oil change
Old Aug 17, 2006 | 07:32 PM
chicken-n-rice's Avatar
You would put it where the oil cap is. Let it run through for a litle while, then drain. If you've never used it before, get ready for a load of **** to come out.
Old Aug 17, 2006 | 07:33 PM
kcryan's Avatar
No he wants to do it through the intake, not the oil
and for the oil i highly reccomend against seafoam on a car u care about, look into auto-rx, a few $ more, but much better, and much safer
JoshG
51
Sep 21, 2015 10:41 PM
f.matejaiii
Sep 21, 2015 12:09 PM
blakkheartt12
Sep 17, 2015 08:11 AM
97_GXE
Sep 15, 2015 06:47 AM
ag90fox
Sep 9, 2015 12:22 PM
