MAF Cleaner? Anyone tried it?
Old Aug 21, 2006 | 07:13 AM
Taxvictim's Avatar
Popular Mechanics has a blurb about a new Mass Air Flow sensor cleaner. It's an aerosol spray designed to be sprayed directly onto the MAF. Supposedly, it helps dissolve any greasy coating that has formed on your sensor from years of air flow over it.
The article recommends that you remove that section of air pipe from the car, then spray the cleaner into the pipe, onto the MAF, from both sides. Let it dry, then do it again. Repeat several times.
The MAF sensor works by sensing the air and temperature the flows over it. As junk starts to build up on the MAF, the computer assumes there is less airflow over the sensor, and compensates for that by changing the air/fuel ratio. This cleaner can supposedly help a rough engine start running smoother again, only because the computer is getting a more accurate reading.
Has anyone tried this? Sure would be cheaper than a new MAF sensor. The article says that dealers never try to clean a MAF, they just replace it at huge cost to the customer.
Old Aug 21, 2006 | 07:16 AM
sean05's Avatar
I usually stay away from any thing dealing with the MAF. Do you have a link to the article? Seems pretty interesting.
Old Aug 21, 2006 | 07:20 AM
Taxvictim's Avatar
D'oh! I didn't even think to see if the article was online:
http://www.popularmechanics.com/auto...c/3297276.html
Old Aug 21, 2006 | 08:48 AM
foxracing12's Avatar
theres been sensor cleaners around for a while. my friend used them on his car and i guess helped with his idle problem
Old Aug 21, 2006 | 08:53 AM
96Turbo3.5's Avatar
you can use an electronics cleaner that doesnt leave any residue. i know lowes sells it in the electrical isle but since im having a brain fart at the moment i cant think of the brand. its only made for electrical connections and various stuff like that. works extremely well.
Old Aug 21, 2006 | 06:40 PM
99grnmaxgxe's Avatar
I've seen a post in the Fluids and Lubricants section talking about a CRC MAF Cleaner.
Old Aug 21, 2006 | 08:49 PM
zeeman's Avatar
i cleaned mine a few weeks ago. Nothing bad happened.
Old Aug 21, 2006 | 10:49 PM
nguyen925's Avatar
did anything good happen at least?
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
dcardello
Sep 3, 2015 11:44 PM
