replacing y pipe
Old Aug 22, 2006 | 03:15 PM
zeeman's Avatar
replacing y pipe
i may be getting a y pipe and putting it on. I am afraid of breaking my studs on my headers. DId anyone encounter this problem or anyone have suggestions or cautions i should look out for?
Old Aug 22, 2006 | 03:41 PM
MaximaSE96's Avatar
Maxima Owner
soak them with Thrust Penetrating Lube....10x better than PB or any other ****
Old Aug 22, 2006 | 03:45 PM
JwaxMax99's Avatar
TPL where do you get that....
Old Aug 22, 2006 | 03:51 PM
zeeman's Avatar
anyone here actually break any studs??
Old Aug 22, 2006 | 04:22 PM
NmexMAX's Avatar
dot dot dot ...
On my hub yes..
Just spray the hell out of (AKA soak) them with any type of pentrating oil...But you already reat that up there so but
Old Aug 22, 2006 | 05:25 PM
zeeman's Avatar
ok one more question. Are the y pipes for 95-98 max all the same regardless of fed spec or cali spec? The seller claims its cali spec but the picture of the pipe looks like fed-spec.
bump
Old Aug 22, 2006 | 07:18 PM
konak85's Avatar
bump
i think they are different.
I did about four Ypipe installs and haven't broken any manifold bolts or studs, they are fairly strong studs. I did partially strip a couple though and they still bolted up okay.
Old Aug 23, 2006 | 05:12 PM
dukie's Avatar
I would suggest taking it to a mechanic
JRod28
Dec 29, 2023 09:56 PM
Cotozic
Jun 28, 2017 08:01 PM
stromm
Aug 27, 2015 04:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
