rough idle due to air filter?
Old Aug 24, 2006 | 08:32 PM
nitink's Avatar
Today I went to a Nissan stealer for some solution of
1) Very rough idle
Car starts with a squeeling sound @ 1500 rpm, comes down to 1100, and goes up and studies at 1300rpm. I let car warm for good 3-4 minutes idle will come back at 600rpm
When I put car back to Park, Idle will shoot up again to 1300-1500 rpm and car gets gas somehow.
2) Stalling in Gear
If I have AC on and put car in gear the car will stall immediatly. It does n't happen every time happens like 1 in 15 times. But once it start to happen It continues to happen for good 45min to 1 hr.
Anyway Stealer's mechanic failed to find anything wrong with the car, heck they couldn't even replicate stalling issue.
In the End mechanic told me that " My airfilter is cause of rough idle and its a know thing with Nissan's & adviced me to go back to stock air filter". I have a K&N Cone air filter which is dirty,
I am wondering is mechanic correct, Can really an air filter cause rough idle?.
Old Aug 24, 2006 | 08:35 PM
Nissan 6's Avatar
yes it can.........
Old Aug 24, 2006 | 08:37 PM
Tatanko's Avatar
Bacon Lover
One that's too small can do the same thing. Ask me how I know
Old Aug 25, 2006 | 12:40 AM
moogotzskillz2's Avatar
my old 95 had almost the same problems... it stalled when i first crank'd it up.. So some one on the org told me to try to clean my intake, so i searchd and found a SEAFOAM write-up through the brake booster line.. with a tune-up (spark plugs, oil, fuel/oil filter) and that really helpd alot... it ran alot smoother and had alil more kick out of it...hope this helps good luck and let us know whats up?
-moo
Old Aug 25, 2006 | 03:52 AM
njmaxseltd's Avatar
Check the resistance of the ECTS, make sure it's within spec according to the temp/resistance table. The Haynes shop manual has the table.
Clean both the throttle body and the IACV. Make sure the idle is set correctly on the default throttle body stop and the IACV. Again, the Haynes manual has the procedure or just search this site.
I call on the dirty K&N filter, but do clean it.
Old Aug 25, 2006 | 06:31 AM
99grnmaxgxe's Avatar
For #1, sounds like a TPS sensor to me.
Old Aug 25, 2006 | 07:13 AM
96Turbo3.5's Avatar
a rough or inconsistant idle can also be a mass air flow sensor that is dirty. it can especially happen when using an aftermarket air filter like a K&N that uses oil to filter the dirt. the oil can, over time, puts a small film on the wires on the mass air flow and will cause erractic readings for the computer. use some good contact cleaner to clean it.
Old Aug 25, 2006 | 01:26 PM
goldtooth's Avatar
or clogged injectors.
Old Aug 25, 2006 | 09:56 PM
I-30BLACKDEMON's Avatar
I just cleaned my K'N and had a fast idle problem for few days. I'm not sure but I think it could have been oil on the MAF. A few days later it was back to normal.
Old Sep 18, 2006 | 08:53 PM
eMart85's Avatar
Dude, it can cause that but not if you have a K&N in. Its probably something else like a sensor or spark plugs/wires or something like that. Run an engine diagnostic.
JoshG
51
Sep 21, 2015 10:41 PM
97_GXE
20
Sep 17, 2015 08:12 PM
thenewguyy
Sep 12, 2015 11:12 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
