Sunroof Drains?
Sunroof Drains?
Has anyone else ever had a problem with their 95 maxima's sunroof, I bought the car used so I'm not quite sure if there were any seals broken but I have a bad leak that comes out of my overhead light, where the sunroof controls are.
Has anyone had this problem before? If so any ideas? I would also like to be sure my drains are clear but I havn't been able to locate them.
I've had that problem .. what u have to do is tilt the sunroof up enough so the seals on the sunroof close ... u should do this before the sunroof controls stop working on u ... mine stopped working so I had to prop up the sunroof with a pen until I could get new sunroof control/maplight ... I know it sounds stupid but it's easier than replacing the whole sunroof assembly .... good luck
Ali
Ali
if the glass is not level with the roof you can get shims from the auto parts stores. I have seen them in the HELP section at VIP/Autozone. There are 4 drains (one at each corner), they run down the pillars and exit behind the rear wheels and somewhere near the fire wall. they could be plugged up, its not uncommon.
Forge277
Jun 13, 2016 09:26 PM
