steering issue?
Old Sep 11, 2006 | 04:51 PM
Valentine's Avatar
steering issue?
hey i got a 97 max and my question basically is this is there any way to make the steering wheel stiffer (harder to turn). mine feels really loose (if your doing like 60 on a straight line u can move it back and forth approximately 1/4-1/2 inch without making the car move from a straight line). also the wheel shakes alittle. any sugggestions? i was told i could just tighten something and that should help but the question is what?
Old Sep 11, 2006 | 05:58 PM
dgeesaman's Avatar
Maintenance Monster
There is nothing to tighten that will remove play. You have a bad outer tie rod, inner tie rod, or steering rack.
If you tighten the pinion tension nut on the steering rack, you will increase the overall resistance to turning the wheel. However, that doesn't remove play.
Dave
Old Sep 14, 2006 | 01:05 PM
97maxgxe420's Avatar
i have the same problem, and i have a gxe.....is it the suspension or is my front tie rods or steering rack?
Old Sep 14, 2006 | 01:43 PM
dgeesaman's Avatar
Maintenance Monster
It could be any of them. A good alignment tech/mechanic should be able to pinpoint the problem.
Dave
Old Sep 14, 2006 | 08:15 PM
jasonv's Avatar
check your column to the rack or to the steering wheel. one of those should be loose
Old Sep 15, 2006 | 03:16 AM
dgeesaman's Avatar
Maintenance Monster
Those are both splined connections. If they were loose you'd feel a nasty grinding sound and the wheels wouldn't turn.
Dave
lowpost99
Oct 26, 2025 06:53 PM
gustavison
Oct 4, 2015 06:50 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
pktaske
Sep 4, 2015 08:40 AM
