squeaky belt
if you have a haynes guide, to check the tension it says to find a belt span of about 11 inches from pulley center to pulley center and lay a flat object across the top of the pulleys, the belt should only flex about 1/4 of an inch. the belt change wasn't really that hard of a job anyway so just take it off and check it. when i changed mine, i got a BF goodrich belt and i ended up with a cool supercharger type whirring noise. i put the same kind of belt on my moms minivan and got the same sound effect. it was kind of funny
i think it was the belt that has the power steering and alternator on it, i really hate that it does that, i started my car to leave school and it sqeeled like crazy infront of everyone
ill take it to the shop i had to replaced at 2moro
Power steering has it's own belt. It only goes from the crank to the pulley on the (power steering) pump. The other belt (acc) is AC/ALT/crank.
I doubt it needs to be replaced, just tightened.
05' MaximaMan
Oct 8, 2017 06:36 PM
