AGX's and stock springs: what settings?
Old Sep 17, 2006 | 05:17 PM
dr-rjp's Avatar
I'm going to use AGX's with my stock springs. Anyone else run this setup, and if so, what setting on your AGX do you use.
Old Sep 18, 2006 | 04:03 AM
njmaxseltd's Avatar
Front:
If you want a soft ride use 1 (AGX don't ride soft on any setting)
If you want a hard ride use 4
Rear:
If you want a hard ride use 8
It's really up to YOU and YOUR driving preferance. Takes less then a minute to change the settings, so play around until you find a setting you like best.
Old Sep 18, 2006 | 07:51 AM
Bassman607's Avatar
I have AGX's with stock springs in my '97 GLE. The setting #1 on the front and #2 on the rear are equivalent to stock. #2 front and #4 rear are 15% stiffer, equal to GR2's. The higher settings are for shorter/stiffer spings. Up to 225% of stock. The stock settings was ok if that's what you like. I run settings of 2 & 4.
Old Sep 22, 2006 | 11:39 AM
dr-rjp's Avatar
Thanks, everyone. I'll try 2 & 4, for starters.
Old Sep 29, 2006 | 03:36 PM
dr-rjp's Avatar
The fronts have the 4-position screw on top, and the rears have the 8-position dial.
Is that normal?
Old Sep 29, 2006 | 03:53 PM
mtrai760's Avatar
'Trynna' is not a word
Yes it is.
Old Sep 29, 2006 | 04:22 PM
mzmtg's Avatar
Minister of Silly Walks
I run 2F/5R
Old Oct 2, 2006 | 02:04 PM
dr-rjp's Avatar
Originally Posted by mzmtg
I run 2F/5R
What kins of improvements can I expect with these settings...particularly in reducing body lean?
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
BkGreen97
Apr 2, 2016 05:47 AM
240tomax
Sep 13, 2015 03:28 PM
