Starter gone bad
Old Sep 20, 2006 | 11:07 AM
ILLeSt MaX's Avatar
Starter gone bad
today my car wouldnt start... i figure my starter went bad... does anyone know what the typical price a mechanic would charge for parts and labor?
Old Sep 20, 2006 | 11:35 AM
Black Maxima
I'll do it for $30 bucks. Just supply the starter.
Old Sep 20, 2006 | 11:36 AM
CRiME's Avatar
oem ftw!
do it yourself. you literally remove two bolts, take out the old starter, put the new one in, and replace the two bolts. you will save yourself probably $100 in labor. The starter itself will cost you between $130 and $175.
This is how you remove it: http://www.motorvate.ca/mvp.php/516
Old Sep 20, 2006 | 11:40 AM
JSMax's Avatar
Sold
It's sooo easy to do your self. Remember to disconnect the battery and get a long breaker bar for that bigger bolt. IT's probably about 4 inches long and a real mudderfcuker to get out.
Old Sep 20, 2006 | 12:00 PM
MDeezy's Avatar
Pay Black Maxima to do it.
Old Sep 20, 2006 | 12:04 PM
Black Maxima
Werd. But, I won't drive down to MD to do it.
Old Sep 20, 2006 | 12:18 PM
WhiteMaxima9600's Avatar
Yeah drive down to the dirrrty south and i'll fix ya up for 20 bucks.....
Old Sep 20, 2006 | 12:22 PM
svojs's Avatar
Yes, it's pretty easy to DIY.
Remember to hear what SMax said.
1) Disconnect battery (the neg. terminal)
2) Get a wrench long enough or a cheating pipe. The long bolt is really a m*****f*****.
GOOD LUCK
Old Sep 20, 2006 | 12:35 PM
MDeezy's Avatar
you'll need to remove the intake if you have the stock intake still. It would be very much in your way. Aftermarkets I'm not sure you probably can get your hands and tools in between there to get the bolt off. 1st bolt close to you is 14mm, 2nd bolt is 17mm. With a 2'-3' brake bar, the bolt will be very easy. even with a normal length ratchet you can get it, but be prepaired to put a lot of force on the end of that ratchet.
Old Sep 20, 2006 | 12:43 PM
Black Maxima
Yea that 17mm bolt is a big MUTHERPOURONLKSFN34w)($&*#()OPF. I had to use like a makeshift 3 foot bar.
Old Sep 20, 2006 | 12:48 PM
ILLeSt MaX's Avatar
i would love to have black max do it, but hes all the way up in CT, and im in dealware.. im at a point where the car doesnt even start.. its sittin in my garage.. but ill def try to take a look at it myself. thanx for the help and all the replies everyone. i really appreciate it.
Old Sep 20, 2006 | 12:49 PM
svojs's Avatar
Yeah, removing air duct is another fun part, especially for the stock ones. You will need to disconnect couple of sensors (MAF & intake air temp, I think) and the L-shape air guiding pipe.
In the mean time, you can also do
1) Clean the throttle body.
2) Clean the MAF sensor.
Old Sep 20, 2006 | 12:55 PM
CRiME's Avatar
oem ftw!
I forgot to mention, before you go about replacing the starter, what exactly are your symptoms? it's also possible that your ignition switch has died. do you at least get a click from under the hood when you try to start it? If you hold the key in the start position for a few seconds, and or shake it around a little, does the car start? If this is what you're experiencing, then your problem is probably your ignition switch, which is a lot cheaper, about $30. If you're getting a click or any noise from under the hood when you try to start, then it's more likely that your switch is good and your starter has gone bad. Either way, both repairs are very easy.
Old Sep 20, 2006 | 03:30 PM
sam29281's Avatar
test the starter
It's easy to take out/install the maxima starter. Get a free test...virtually every part store will do it for you free of charge. I'm sure you know your battery is fine right?
Ignition switch is usually the culprit if the starter is good.
the relay is the last you should check because it rarely go bad. Good thing it's cheap.
Old Sep 21, 2006 | 06:13 AM
Maguwa's Avatar
I forgot to disconnect the battery when I was installing my starter...needless to say I got to see a lot of sparks.
Old Sep 21, 2006 | 06:27 AM
MDeezy's Avatar
thats a whole lot of fun!
chisam14
Nov 6, 2018 08:56 PM
RealityCheck
Oct 2, 2015 06:34 PM
maxima297
Sep 30, 2015 03:32 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
