Rough cold starts
Old 09-23-2006 | 12:24 PM
86maxima96's Avatar
I Broke OT
Rough cold starts
When I start the car in the morning or whenever, it cranks really rough. I'll give it a second, and then crank it again and give it a little gas (not sure if that does anything) and after some more rough cranking it will start up. Once it's started, it idles just fine and runs great. I'm pretty sure the problem is the starter but just want another opinion. I don't think it's injection or anything related to that as it runs just fine after it's started. And just to get an idea, it's at 116k with the stock starter, so I wouldn't be surprised if it's time to get a new one.
Old 09-23-2006 | 11:31 PM
Digitized's Avatar
any error codes?
Old 09-24-2006 | 06:15 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
dont give it gas its fuel injected let the computer handle that. if you cant start it without pressing the gas youve got a problem.
Old 09-24-2006 | 06:51 AM
MDeezy's Avatar
its possible to be the starter. Greese is drying up, you crank a few times and it doesnt start. When it does it will start a bit rough as its burning off some of that unburn fuel from the previous cranks.
How are you spark plugs?
IACV clean?
TB clean?
PCV clean? (you can soak this in carb cleaner and it will break up most carbon deposit inside)
Old 09-24-2006 | 08:45 AM
WhiteMaxima9600's Avatar
My car has this problem a little when the temp is 40 or below, dunno.... cleaning the throttle body helped a little
Old 09-24-2006 | 09:27 AM
crazy97's Avatar
Have you had any tranny work done recently? If so the ground to the starter side of the tranny could be messed up. I had to run a ground to my starter to cure terrible starts. That thread is in my sig...
Old 09-24-2006 | 10:55 AM
njmaxseltd's Avatar
A "rough crank" leads me to believe you have a starter failing.
gustavison
10-04-2015 06:50 PM
97_GXE
09-15-2015 06:47 AM
QueensMAX
09-15-2015 04:14 AM
ballerchris510
09-10-2015 09:35 PM
trungg86
09-04-2015 04:58 AM
Quick Reply: Rough cold starts
