How to clean dirty yellow headlights
hey guys, just searched our how to's to find this out and i didnt see a how to. so after searching google heres what i found:
-head over to autozone and buy some Mother's Aluminum and Mag polish.
-get a rag, rub the polish into the headlights with a little elbow grease
-when it turns a little blackish, wipe it off with a clean rag
-headlight should look as good as new!
If really bad:
-wet sand with 1500-2000 grit sand paper then follow steps above spending about 20-30 mins per light. that should get em lookin nice!
other things that work well:
-blue magic plastic polish
-Meguiar's Scratch-X
just thought a bunch of you would find it useful! plus maybe itll get thrown in the how to's
credit given to: www.dsmtalk.com/forums members
If really bad:
Originally Posted by ethnic6
ahh walmart, what won't they sell short of little thai boys and muscrats...
i did that today. i baught this kit from walmart that goes with a drill. its a liltle foam polish pad(no to be confused with a power ball). its flat hard foam and it worked quit nicely. took about 5 minutes tops.
I bought some plastic restoration polish form Autozone, which included a pieces of different numbers of sand papers. Took me about an hour. The faded yellow headlights became clear again. Cost me about 14.99 plus tax.
I just went out and got some of that Mothers polish for 4 bucks and tried it out. I'm impressed. My headlights (left more than right) had turned yellow and cloudy over the last year. It made them clear again! I mean, it's not like brand new, but you wouldn't know unless you got really close.
If I'd known that it would work this well I would have taken a before pic.
Here is a pic from 8 months ago (you can see it was starting to get cloudy back then)
Here is one from 10 minutes ago
Here comes a question. I got a light bulb exploded in the assembly. The whole thing was coated with powders, and quartz pieces. Is there any way to clean it without taking it all apart? It's nasty. I got it clean, but not as good as the original.
Okay....I did all recommended above, and it is a lot cleaner, but not quite 100%.
I bought the Mother's Aluminum and Mag polish and it never turned blackish on the lamp?? Am I supposed to let it sit for a few minutes?
Should I have bought the Mag's plastic polish?
If walmart had had plastic polish I would have gotten some, but they didn't so I used Mother's Mag and Aluminum. It never turned black. I just kept rubbing it on the light with a rag for about 10 minutes, then wiped it all off to reveal the cleared up lense.
[QUOTE=t65k3]Here comes a question. I got a light bulb exploded in the assembly. The whole thing was coated with powders, and quartz pieces. Is there any way to clean it without taking it all apart? It's nasty. I got it clean, but not as good as the original.[/Q
Same thing here...how do you get the inside clean ???
The Mag and Aluminum polish worked pretty well at getting rid of the yellow cloud, but probably won't do anything for scratches. If you have it available I'd be willing to bet that the plastic polish gives better results. I wouldn't know which one to use though. Prolly alll good.
Originally Posted by ik95
can u use Meguiar's Plast-X to restore fog lights????
If it's not gonna help, you can return it to autozone and say you didn't use it
That picture in your sig is blurry, you'd need to perform the same procedure to your camera, buff those yellow's out or something. LOL. J/K.
Good thread, though. My headlights' been old, but never got the yellow's yet.
I sanded some foglights
All i used was sandpaper and things below. I started with 60 or 100 and worked my way up to the fine, 2000
.. never tried it on headlights but doing the foglights took me a lot of time. didnt use the
left sanded - right unsanded.
the stone chips are still visible... at close observation but still look better than on the right.
I also don't have glass polish so i used chrome/metal polish and then plastic like finish stuff - Black Magic
*not taking any responsibily if it doesnt work for you*
shilov
02-19-2024 09:40 PM
AaronL
11-15-2020 11:52 AM
doctorpullit
07-20-2019 09:31 PM
sdotcarter
09-02-2015 09:53 PM
