taking off and cleaning headlights
Old Oct 2, 2006 | 06:09 PM
NismoMax1119's Avatar
i cannot figure out how to get my headlights off. they are foggy and i want to clean them. if anyone could explain to me how to get them off that would be great. sorry for the newb question.
Old Oct 2, 2006 | 06:32 PM
99se5speed's Avatar
SHIFT_up
http://forums.maxima.org/showthread.php?t=493450 <- try that first?
It's not the easiest thing to take the lights off. Requires the grill to come off and i believe 4 bolts holding in each light.
Old Oct 2, 2006 | 06:40 PM
okay ill check that thanks alot
Old Oct 2, 2006 | 06:43 PM
mikem29ss's Avatar
Hi, Speaking of headlights, are these worth it?
http://cgi.ebay.com/ebaymotors/ws/eB...ADME:B:EF:US:2
Thanks,
Mike
Old Oct 2, 2006 | 06:49 PM
umm yea i ran in trouble because i couldnt get the plastic clear part of the headlight off. i didnt take the grill off though so maybe i will try that. if anyone else has done this let me know if you ran into any trouble with that. thank you
Old Oct 2, 2006 | 06:55 PM
Cdg2125's Avatar
Yeah to take out the lights take off the grille. Undo the four bolts and the should pop out. Just heat them up in the oven and carefully pop off the plastic.
Those headlights are worth it if you want them.
Old Oct 2, 2006 | 06:58 PM
mikem29ss's Avatar
Do you think they are as bright if not brighter than stock? thanks
Mike
Old Oct 2, 2006 | 07:17 PM
thanks alot. yea i was trying to pop them off with a flat head but it wasnt happening easily and i didnt want to break anything. thank you for the help
Old Oct 2, 2006 | 07:22 PM
Cdg2125's Avatar
Mike
Yes they should give a little better light since they should reflect more.
Nismo, did you heat them up before or just try to pop them off?
Old Oct 2, 2006 | 07:48 PM
MaxSpeed97's Avatar
I wouldn't even try to heat them and take the lens off if it's your first time messing around with headlights you may get condensation in them when you put them back together. If you have the main headlights out just wet sand and buff them like that and if not just keep them in and mask off, that s what i did and they came great. good luck
Old Oct 2, 2006 | 07:57 PM
matrix11229's Avatar
Just get Meguire Plast-X at Autozone and in 5 minutes your headlights will look almost like new.
There is no need to remove them.
Old Oct 2, 2006 | 08:13 PM
Cdg2125's Avatar
Yeah well if the dirt is inside there is a need to remove them.
Why shouldnt he take them apart? Should learn how to do it some time. It's not hard at all. And you just heat them back up and use a belt to push keep them together. I've taken them apart 4 times and have no condensation problems.
Old Oct 2, 2006 | 08:52 PM
4thGenMaxima99
Ok if you get piaa white lights would be good to see the road better then stock ?
Old Oct 2, 2006 | 08:57 PM
goldtooth's Avatar
Don't do it, it will cause you to go blind!
Old Oct 2, 2006 | 09:00 PM
4thGenMaxima99
Ok. Can you put on 95 96 glass headlights on a 97 Maxima ?
Old Oct 2, 2006 | 09:03 PM
Cdg2125's Avatar
Wow....ok. Why would you put 95-96 glass on when you can just get 97 glass lights? Obviously PIAA bulbs will see better than stock bulbs. If you're going to get PIAA bulbs then you might as well do the 9007 upgrade and get major light output, or depending on where you get the bulbs (what price I mean) the PIAA might not be worth it. They are expensive and you could save more for a HID kit.
Old Oct 2, 2006 | 09:05 PM
goldtooth's Avatar
IIRC 97-99 have PLASTIC, not glass.
Old Oct 2, 2006 | 09:06 PM
4thGenMaxima99
Im asking because i want to put a hid kit on it but i know that glass would be better then the plastic ones
Old Oct 2, 2006 | 09:08 PM
Cdg2125's Avatar
Yes but I thought he could buy glass headlights for his 97? Am I mistaken?
Old Oct 2, 2006 | 09:09 PM
4thGenMaxima99
No i was asking if you could put 95 96 glass lights on a 97
Old Oct 2, 2006 | 09:13 PM
Cdg2125's Avatar
I know and I was saying that you can get glass headlights for your 97. The 95-96 lights wont fit your max.
goldtooth's Avatar
go with plastic, weight reduction FTW!!!!!!!!!
Old Oct 2, 2006 | 09:16 PM
4thGenMaxima99
Dont care that much about weight
Old Oct 2, 2006 | 09:17 PM
Cdg2125's Avatar
Yeah it's what? 2 lbs extra with glass?
Old Oct 2, 2006 | 09:19 PM
4thGenMaxima99
Plus hid's would look so much better with the glass headlights
Old Oct 2, 2006 | 09:23 PM
Cdg2125's Avatar
Well they won't look much different. The output should be a little better but you probably wont notice looking at it, just actually driving.
Old Oct 2, 2006 | 09:24 PM
4thGenMaxima99
Not if you got a 10000 hid kit
Old Oct 2, 2006 | 09:28 PM
Cdg2125's Avatar
Where are you getting the kit from? Ebay?
Old Oct 2, 2006 | 09:32 PM
4thGenMaxima99
i dont know but some guy i know in miami has that kit i asked him but he didnt want to tell me.
Old Oct 3, 2006 | 04:23 AM
mikem29ss's Avatar
I found those lights on ebay. They are the only clear euro style I seem to be able to find for a 95 maxima. Maybe I'm not looking in the right places. I like the clear head light look though.
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
crazyespn
Sep 3, 2015 01:30 PM
sdotcarter
Sep 2, 2015 09:53 PM
iflexsteel
Sep 2, 2015 08:04 AM
