Another MIL Problem, right after I fixed the first one!!!
Old Jun 27, 2001 | 09:10 PM
vmok's Avatar
OK, so for the past 15,000miles, I had the check engine light on, and every time I checked it, it noted bad front O2 sensor, left bank. I recently changed both left and right front o2 sensors because I figured it was time (135,000miles).
I reset the MIL light, and low and behold, not even 600 miles later, the MIL light comes on, and this time, it shows 0903 and 0705, which is Evap Canister Vent Control and Evap Control System respectively (according to the VBx site).
Does anyone know what's the cause of this (ok, no stupid answers like it's the Evap System...) and what I need to do (or replace) to fix it? Thanks. Also, are there any adverse effects to driving with a non-funcitonal Evap Control system besides not passing smog in California (I'll just have to reset the light again before I smog as usual...)
-V
Old Jun 29, 2001 | 01:48 AM
vmok's Avatar
-V
Guess nobody knows?
Old Jun 29, 2001 | 06:25 AM
NickStam's Avatar
My evap canister 'seized' at around 34k. I forget exactly what it's purpose is. Have you checked the MIL Diagnostic sticky? The EVAP canister is located near the rear drivers' side wheel.
Old Jun 29, 2001 | 06:33 AM
Daniel B. Martin's Avatar
-V
You will find useful information about these related Diagnostic Trouble Codes in the Sticky titled ECU Diagnostic Trouble Codes. It includes a procedure for bench testing the EVAP Canister Vent Control Valve. You might also remove the canister and dump out any water which has become trapped inside.
Old Jun 29, 2001 | 01:51 PM
vmok's Avatar
thanks. will check it all out.
-V
Old Jun 29, 2001 | 02:39 PM
97MaximaSE's Avatar
same thing is happening to me...let me know if you fix it and what was wrong
Mar 12, 2020 12:06 AM
thenewguyy
Sep 12, 2015 11:12 AM
conansriver
Sep 11, 2015 10:26 AM
Colossus
Sep 9, 2015 05:46 AM
slowlifer
Sep 8, 2015 05:53 AM
