intake manifolds
intake manifolds
ok the middle eastern variable intake. this is a direct swap right but i thought it was just the black plastic manifold off a 2000 model maxima with 222 horsepower. is this all you have to swap out can you do this or do you have to do that switch and vacuum canister stuff and all. also what is the horsepower increase it's not 32 horsepower like the 2000 maxima's is it
MEVI and 00vi are totally different....to run the MEVI u have to run a vacuum canister..RPM Switch MAP/BARO Solenoid...manifold wise its a bolt on.the ALL MOTOR forum has all the Info u need on the MEVI and 00vi...the 00vi is a lil more extensive on teh install
MEVI
http://forums.maxima.org/showthread.php?t=217001
00VI
5th gen VI in a 4th gen:
http://forums.maxima.org/showthread....2&page=1&pp=30
http://forums.maxima.org/showthread.php?t=353888
http://forums.maxima.org/showthread.php?t=362040
http://forums.maxima.org/showthread....highlight=00vi
http://forums.maxima.org/showthread....78#post4065778
OOVI SWAP: Need Grocery List to get everything I need
00VI
maxima297
09-30-2015 04:32 PM
