Brake light is on
Old Oct 12, 2006 | 09:58 AM
maxim82's Avatar
Brake light is on
the brake light remains on even after i release the emergency brake has anyone had this issue before? what did you do to take care of it?
Old Oct 12, 2006 | 10:15 AM
Bassman607's Avatar
Your brake pads have worn down to the point that your brake fluid is low in the resivior. You can add more fluid or change pads to turn the light off.
Old Oct 12, 2006 | 10:29 AM
MDeezy's Avatar
acutally there is no sensor on in out braking system that will illuminate the the brake light to indicate low brake pads.
Most common cause would be low brake fluid, check it and add more if needed. Better solution would be a full brake bleed to get all/most of the old fluid that is old and boiling off anyway out of there. If that doesn’t solve it check the e-brake cable that its not stuck or jammed.
Old Oct 12, 2006 | 10:32 AM
Max_Out's Avatar
Under the radar
also it could be a sensor in the e-brake thats bad. but thats a long shot.
Old Oct 12, 2006 | 10:34 AM
NmexMAX's Avatar
dot dot dot ...
I think this is becoming sticky mat'l.
Old Oct 12, 2006 | 10:38 AM
VIP Maxima
you need new pads......
Old Oct 12, 2006 | 12:51 PM
troyster's Avatar
just had the same problem on my '98, new pads did the trick!
Old Oct 12, 2006 | 04:37 PM
njmaxseltd's Avatar
Check your blinker fluid.
What do you do when your fuel level is low?
Common sense on this site is at an all time low.
Old Oct 12, 2006 | 11:12 PM
supaneko's Avatar
Yeah, everytime I change my blinker fluid it totally fixes my brake light problem. Although I've noticed that it takes longer to go away when I use synthetic blinker fluid.
Old Oct 12, 2006 | 11:47 PM
nguyen925's Avatar
manual says that its either low brake fluid or your emergency brake is on. hope you dont have air in your lines cause thats not good either..
Old Oct 13, 2006 | 08:48 AM
DuMKuH's Avatar
Mine was on when one of my calipers was leaking.
Old Oct 13, 2006 | 09:18 AM
Bassman607's Avatar
[QUOTE=MDeezy]acutally there is no sensor on in out braking system that will illuminate the the brake light to indicate low brake pads.
The sensor is in the master brake cylinder resivoir. As the pads wear down, the pistons in the brake calipers move out, creating more volum in the caliper. The fluid in the resivoir fills the extra volume and the level goes down. The level sensor in the resivior turns on the brake light.
Old Oct 13, 2006 | 12:48 PM
k-man's Avatar
funny thing is mine came on this morning which was the first cold morning of the year here in Dallas. Checked the fluid level (ok). Ran an errand at lunch and no more brake light? I DO need to change my pads BADLY. Think that might have anything to do with it?
Old Oct 13, 2006 | 01:43 PM
Batxel's Avatar
blah
Yes, you need to change your brake pads. You knew it was a problem now go and fix it
If the brake light is always illuminated there's something worng with your brakes.
Old Oct 22, 2006 | 07:56 AM
mikeh's Avatar
my abs light keeps coming on... mostly when it is raining outside it seems when it does the brakes feel real weird almost dont work any suggestions?
Old Oct 22, 2006 | 08:08 AM
MDeezy's Avatar
I want proof
. . . seriously
Old Oct 22, 2006 | 08:54 AM
ILLeSt MaX's Avatar
i had the same problem.... u need new feet for ur shoes...
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
