just curious
Old Oct 21, 2006 | 09:58 PM
madisonjeanmj's Avatar
just curious
l have a 99 maxima with the 04 18inch rims when i go over 60 mph the tires start to shim a lil ive had them balanced twice what is the reason this is happenin
Old Oct 22, 2006 | 04:18 AM
Trajiksmax's Avatar
Proud Maxima Owner
That's strange same thing is happening to me. I have 235/35/19 Evo's with Toyo Proxes 4. It starts to shim between 70-80 MPH. I had tires balanced, and wheels inspected. Found a tire out of round had dealer replace and the shim was still there. I would like to know the same thing? What could be causing this?
Old Oct 22, 2006 | 06:21 AM
njmaxseltd's Avatar
Extreamly low profile tires are very very sensitive to imperfections in the tire and even rim/wheel/hub runout. Have a professional inspect the wheel and tire combination as well as your vehicles hub to make sure everything rotates perfectly. Hubcentric rings are a must as well. A roadforce ballance might cure your problem.
Old Oct 23, 2006 | 10:24 AM
tdbak's Avatar
Used to be tire shops that would do dymanic balance on your vechicle. Is that what the raod force balance is?
Old Oct 23, 2006 | 10:55 AM
Mxrider52's Avatar
I support for what?
Since you metioned hubcentric rings which are better metal or the poly ones? I cant figure it out both say they are better then the other. I have been running my wheels without them for about 1000 miles and had no problems. If they are tightened properly it shouldnt affect anything.
Old Oct 23, 2006 | 03:13 PM
Trajiksmax's Avatar
Proud Maxima Owner
njmaxseltd,
What is a roadforce balance?
Old Oct 26, 2006 | 05:55 PM
kbz504's Avatar
By shim...u mean vibrate....maxima's are notorious for the shaking over 50mph....what's the deal?
Old Oct 26, 2006 | 08:47 PM
Apparition's Avatar
Ichiban King
yeah my maxima has a shim @ 80mph.. but, so do all the other maximas I've riden in. Anywhere else though seems to be unaffected for the most part.
The Wizard
24
Oct 1, 2015 08:47 PM
lrb6805
Sep 30, 2015 08:12 AM
hot04
Sep 18, 2015 06:14 AM
spidgeon
Sep 9, 2015 03:36 PM
doctorpullit
Sep 5, 2015 04:40 AM
