Where or How can I fix the Camber on my front wheels?
Old Jun 29, 2001 | 09:07 AM
GTRBlkMax97's Avatar
Anyone that knows? I lowered my car with intrax springs and my tires are wearing out like a ***** on the front, I looked at the tires and they are wearing on the inside more than the outside, the car does not pull to one side or the other, so i would guess it is the camber. i know Stealin has camber plates but could I get it done without buying those? Thanks in Advance
Old Jun 29, 2001 | 09:16 AM
Sprint's Avatar
http://www.southwestautoworks.com/maxima.html#95
Alex @ SouthWest Autoworks
I bought Camber bolts from him for $35
alex@southwestautoworks.com
Old Jun 29, 2001 | 09:25 AM
no **** 35 bucks, how do they work Sprint? Thanks
Old Jun 29, 2001 | 09:31 AM
Sprint's Avatar
they go in place of your regular strut bolts.. and the alignment tech will turn them to diffrent degrees to move the wheels so they are straight
Old Jun 29, 2001 | 09:32 AM
ejj's Avatar
ejj
I think www.tirerack.com also sells them, for around the same price.
Old Jun 29, 2001 | 09:35 AM
Sprint's Avatar
yeah but alex is a maxima owner with a business
Old Jun 29, 2001 | 09:39 AM
ejj's Avatar
ejj
Excellent point. I didn't realize that he sold them...I bought my springs from him, and had I known (or asked) I would have bought them from him.
Old Jun 29, 2001 | 09:46 AM
did you put them on? or did the alignment guy do it? And also in order to put them on I am guessing you need to compress the springs again?
Old Jul 3, 2001 | 12:34 PM
Sprint's Avatar
you put them on.. the alignment guy adjust them.. its at the bottom of the strut housing so i don't see any reason to compress the springs again
Old Jul 4, 2001 | 01:27 AM
Chunger's Avatar
My other car is a Hybrid
I've got the Intrax and my camber isn't bad at all... Maybe the Sprints are a little lower though...
I did 'preload' the FSTB by installing it with the front of the car in the air... maybe that helps too...
Old Jul 4, 2001 | 09:40 AM
Eric L.'s Avatar
You'll need camber bolts. It basically replaces the stock bolt that holds together the bottom of the front strut perches. Stock, the Maxima has only one adjustment for alignment: front toe.
Old Jul 4, 2001 | 10:16 AM
bullseye's Avatar
I have a dumb question...
May I assume when you lowered the car, you had an alignment done, too? If so, you should get camber plates or camber bolts as suggested above. If not, I'd get an alignment done first, before I invested in additional hardware. Sorry if that is too basic, but your level of experience is unknown to me at this time... I'm sure I'm about to find out! :-) Good luck.
Old Jul 4, 2001 | 11:59 AM
SC99MaxSELmtd's Avatar
Dropping the Max
I was also wondering what all this may cost to have done. I have Tokico/Eibachs to put on my 99' Max, but when I asked my mechanic how much to put them on he said 300-400 to install, adjust camber, and align. OUCH! Does this seem high for what seems to me to be a fairly straight forward install? Have most of you done the install yourself?
Old Jul 4, 2001 | 01:39 PM
Synki's Avatar
Wow, that is pretty weird b/c i have InTrax as well and the shop was able to put it back to factory specs. To correct it, you can either go with the Ingral(?) camber bolts or the Stillen camber plates (for the big drops).
Old Jul 8, 2001 | 08:38 AM
BEJAY1's Avatar
Conecarver
I've got a camber bolt kit from Eibach I no longer need. $15 to whoever needs it.
I moved up to the Stillen plates. Big difference for me when auto-x. Running -1.7deg when not on the street.
Old Jul 8, 2001 | 08:49 AM
redmaxpa007's Avatar
i SeE what you did therE
Re: Dropping the Max
I think he is ripping you off.. 300-400 is way to much..
most places charge 100-150 to install the springs/shocks
30-50 for a alignment
so that means he is charging you 170-270 to adjust camber.
and besides... you do not need to adjust camber with that
setup... just an alignment is needed...
i have the same setup..
umm... no way...that price is WAY high!!
dear old dad is a mechanic and those prices i gave you were from his shop..
Old Jul 8, 2001 | 09:03 AM
maximus75's Avatar
How far of a drop did you guys go? I lowerd my car 1.5 with Eibachs recently. I havent driven enough to notice any tire wear but I'm afraid of wearing the tires. I didn't bother to check the alignment. Do you think I'll have a prob? Maybe I'll invest in the camber bolts.
Old Jul 8, 2001 | 09:31 AM
I want them if they will work w/ Sprints. E-mail me at rileymcintosh@hotmail.com.
Old Jul 8, 2001 | 12:36 PM
I got the same ones, would it be a good idea to go ahead and put the bolts in and then have a shop adjust them or just have the shop adjust them?
trasmadean
Feb 1, 2017 08:20 PM
homeyclaus
Sep 3, 2015 06:15 PM
twotonezed
Aug 16, 2015 11:41 AM
BassAddictJ
Aug 4, 2015 11:38 AM
