Tweeters
Originally posted by hockeyghst
I am going to mount some tweeters on my door.....where would i connect the wires at??? would i connect them straight to my door speakers????? thanks.......95MAX
Originally posted by DCmax
No, unfortunatley you cant just do that. You need to get a pair of crossovers. Each crossover will split up frequencies and send the higher frequencies to your tweeter and lower frequencies to your woofer (door speaker).
the tweeter already has a crossover built into it....so where would i wire it to now???
Originally posted by bdogg88
My Max has tweeters and front speakers in already... if you have the same set up all you have to do is take out the old tweeters and replace them w/ the new ones.. wires will be fine, the crossover is already in as you already have a tweeter and low range front speaker
Hey Hockeyghst,
I was looking to get a pair of "add on" tweeters myself that have the built-in "crossover." The big thing I'm concerned about is how do you adjust level on these things. I'm sure the sensitivity on these things, as well as placement differences, will mean output mismatching. Ended up scraping the idea because none of the aftermarket "add on" tweeters seem to have provisions for this and I didn't want to spend the big dough needed for separates.
95naSTA
Sep 21, 2015 06:50 PM
ericdwong
Jan 26, 2001 05:51 AM
