mech sprayed wd-40 on my PS belt.
Old Oct 29, 2006 | 07:25 PM
kbmaxima's Avatar
cooling system decided to somehow burst open on my way to work.. the neck on the rad where the upper hose decided to break clean off... got it towed to one of the mechanics i know. (ty geico) got in a new rad, all was fine. just had to leave the old coolant that spilled all over from the upper hose to dry off and wait til the white smoke stops. of course it got over my belts and everything else, so the belts start squealing... ****** sprays wd-40 just as i was takin a phonecall. i flipped.
now i get steering slippage on a cold start. any way to rid of the wd-40 that idiot sprayed on it? will it burn off after time? long story short, got the rad+labor for 100 bucks, bc the shop owner got his ear chewed off by me.
Old Oct 29, 2006 | 07:29 PM
Max_Out's Avatar
Under the radar
take some brake cleaner to it, but make sure you read the label to see if it eats through rubber (i dont know if it does or not). thats all i can think of.
hope this helps.
Old Oct 29, 2006 | 07:41 PM
Anii23's Avatar
Soapy water if it really bothers you, but DONT use brake cleaner. You will be buying a new belt if you do that. Have you tried tightening your belt tensioner? I bet that would fix it. WD is not bad for the belt.
Old Oct 29, 2006 | 07:44 PM
MaximaSE96's Avatar
Maxima Owner
try belt dressing for a few days
Old Oct 29, 2006 | 07:52 PM
MaximaSpd85's Avatar
yeh i didnt know it was bad either, ive sprayed it on squeeky belts plenty of times, but i guess now i know...
Old Oct 29, 2006 | 08:24 PM
jxkim's Avatar
**** on it
Old Oct 29, 2006 | 09:57 PM
Zshopa's Avatar
try some all purpose cleaner/degreaser it will do the trick but make sure u wash it off with some water
Old Oct 30, 2006 | 01:57 AM
Trajiksmax's Avatar
Proud Maxima Owner
Simple Green dilluted in water. Won't harm anything, only the grease on the belt.
Old Oct 30, 2006 | 05:02 AM
njmaxseltd's Avatar
Originally Posted by Anii23
Soapy water if it really bothers you, but DONT use brake cleaner. You will be buying a new belt if you do that. .
The WD will dissapate in a few days. Just leave it alone.
Old Oct 30, 2006 | 09:23 AM
Fr33way™'s Avatar
Wild for Width
It will go away, do not use any kind of solvent.
doctorpullit
Apr 23, 2017 05:35 AM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
markevans999
Oct 25, 2015 08:27 AM
bumpypickle
Sep 19, 2015 01:07 AM
