Autotranny experts inside please
Old Oct 30, 2006 | 08:11 AM
Kevlo911's Avatar
Kevlo for President
My 2-3 shift is very slow and the engine revs inbetween the shifts. What could be the problem? The valve body or the selonloids?
Old Oct 30, 2006 | 08:23 AM
MaximaSE96's Avatar
Maxima Owner
thats tough...because the valve body controls the pretty much the speed of the shift but the solenoids control when and what gear...i would look at VB first...but u can get a solenoid pack for like 150 I dunno how much they charge for VB
http://www.transtarindustries.com/default.asp
Old Oct 30, 2006 | 08:25 AM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
did you check the fluid level? I know that sounds basic, but hey. And if its only that gear i dont know that i would say filter. Is it constant or come and go?
Old Oct 30, 2006 | 08:28 AM
C MAX's Avatar
disconnect the drop resistor and see if it still shifts slow, if it does its probably your clutches.
Kevlo911's Avatar
Kevlo for President
Pretty consistant, I think the tranny is slipping alot lately, but it just started the revving inbetween shifts.
Old Oct 30, 2006 | 09:15 AM
Dubbya's Avatar
VK56 Inside
Revving in between shifts = slippage. Time for a new transmission.
Old Oct 30, 2006 | 09:52 AM
Cdg2125's Avatar
Yep I have the same thing. Just started a few days ago for me...really pissed because I'm about to do my 00vi swap. Gonna finish that then go from there.
Old Oct 30, 2006 | 10:02 AM
shurik's Avatar
Similar problem...
I don't know what that is but I think I have similar proplem in my auto! When I cruise in 2000 RPM and when the gear is ready to shift it revs to 2500 PRM and shifts! Hmmmmm I think I started noticing that after the trany oil change! Have no idea what that could be!
Old Oct 30, 2006 | 10:06 AM
BlackCat's Avatar
RIP '98 Maxima SE
signs of band wear
getting close to a tranny rebuild
Old Oct 30, 2006 | 10:07 AM
Cdg2125's Avatar
I'm hoping it's tranny fluid or something. I dont want to spend a **** load for a new tranny. Def. try to get a VLSD tho if I need a new tranny. What's the price for a rebuild?
Old Oct 30, 2006 | 10:15 AM
scubasteve's Avatar
sometimes you can get the bands adjusted for a little more life. Usually enough to save the $$ for the new/rebuild tranny
Old Oct 30, 2006 | 10:17 AM
Kevlo911's Avatar
Kevlo for President
Fck this really sucks. Good think alot of people do manual swaps. I can pick up one(an auto) for cheap.
Cdg2125's Avatar
Well a friend here at school, her father owns a auto shop. I'm wondering if he could give me a deal on rebuilding the tranny. Would replacing/fixing the bands fix the problem or is just something that would give a little more time before a rebuild?
Old Oct 30, 2006 | 07:08 PM
scubasteve's Avatar
Depends on what is wrong with it. Typically when you rebuild a transmission you replace more than just bands, because you are already there so why skip essentials? If the bands are worn and have some adjustment left in them you can sometimes adjust them and limp around for another month or two while you save $$.
Old Oct 30, 2006 | 07:45 PM
chillin014's Avatar
yeah ive been driving hard in my auto and i can tell its not shifting how it used to. I would like to see a basic write up of an auto tranny swap (to another auto) cause i have no problem doing the labor myself but i've heard its really not that hard.
Old Oct 31, 2006 | 09:56 AM
Dubbya's Avatar
VK56 Inside
I replaced mine with a junkyard one 60,000 miles on it. $400. Installation was $450 and I upgraded the VB to a stage 2 at the same time.
Old Oct 31, 2006 | 12:26 PM
Cdg2125's Avatar
That's a lot of $$. How hard is the installation if I find a cheap tranny?
Old Oct 31, 2006 | 01:01 PM
heynow's Avatar
that's actually a very nice price for that tranny Dubbya!
Old Nov 1, 2006 | 10:06 AM
Kevlo911's Avatar
Kevlo for President
Fluid KINDA looks low, not really, but ima add some today and see if it helps.
Old Nov 1, 2006 | 10:47 AM
C MAX's Avatar
did you unplug the drop resistor, you'll be surpised that the slipping will stop completely until you decide to fix it.
Old Nov 1, 2006 | 10:59 AM
heynow's Avatar
So what's the deal with the drop resistor?
Old Nov 1, 2006 | 01:11 PM
97GoldGLE's Avatar
Had mine rebuilt like a yr ago cost me $2600 and it broke 3 times during that year.... still shifting hard 1-2 shift not happy at all...
Old Nov 1, 2006 | 02:39 PM
Dubbya's Avatar
VK56 Inside
Thats exactly why I bought a used one and just replaced it. $2600 and it most likely wont be the same. $850 for the replacement installed and it works like a champ.
Old Nov 1, 2006 | 03:14 PM
Cdg2125's Avatar
Sounds good dubbya. I got offered an 01 AE tranny with VLSD for $550. I might take that depending on how much the labor would be....
Old Nov 1, 2006 | 03:47 PM
heynow's Avatar
is it gonna work on a 4th gen?
Old Nov 1, 2006 | 04:35 PM
NmexMAX's Avatar
dot dot dot ...
Exactly a year ago today .
http://forums.maxima.org/showthread.php?t=437743
Old Nov 2, 2006 | 04:05 AM
C MAX's Avatar
it stops the lag in between eliminatng the slipping of the clutches. its the silver box on the driver side shock tower. its almost like the vb mod its a quick solid shift. this will at least keep the car from lagging until you decide to fix it properly.
Old Nov 2, 2006 | 04:41 AM
1FSTMAX's Avatar
its time for a 5spd kev..
Old Nov 2, 2006 | 10:03 AM
mbandi's Avatar
Da'Burgh, Go Stillers!
By raising transmission line pressure to max. Do it if you like, but if you end up rebuilding the auto you will more than likely have more hard parts to replace and thus spend more money.
Old Nov 2, 2006 | 10:10 AM
loverholic's Avatar
iAMIXAM!
doesnt that make the tranny heat up more?
Old Nov 2, 2006 | 10:35 AM
C MAX's Avatar
i did it to mine for over two years and had no ill effects, and since his tranny is done anyway it will by him more time. we do this as a mod here in case you dont know jime has done it for yrs also. its called the drop resistor mod.
Old Nov 2, 2006 | 10:39 AM
C MAX's Avatar
yes it does, a tranny cooler will help. but as a bandaid for a badly slipping tranny this will keep it up and running till it's replaced. its more likely bad clutches anyhow so the tranny's on its way out either way. when my level ten tranny went bad i put my stock tranny back in and unplugged the drop resistor and wound up keeping it in for the whole winter and it rode fine till i got my level ten fixed.
Old Nov 2, 2006 | 11:18 AM
mbandi's Avatar
I'm familiar with it, and as we all know, Jime knows what he's talking about.
Old Nov 2, 2006 | 01:49 PM
loverholic's Avatar
iAMIXAM!
i've always wanted to do it, but i was scared that my tranny will only go out faster.... i drive 15 miles to work... i am about to do it to work and see how it runs...... hope my tranny dont blow up...lol j/k
Old Nov 2, 2006 | 06:20 PM
Kevlo911's Avatar
Kevlo for President
I added tranny fluid and it helped for the short time the car ran lol. I will give another update after I change the fuel stuff.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
