Fan not working at position 1 but works well on 2,3,4… what’s going on?
Old Oct 31, 2006 | 04:46 PM
sickmen's Avatar
My max interior fan does not work at setting 1, however it works fine on 2,3,4 positions.
When I turned on the AC and put the fan on position 1 then I could hear the AC unit working but no air is coming out… again position 2,3,4 work well.
What seems the problem? I know it’s not the resistor problem since the fan is working on position 2 and 3. Any thoughts?
Old Oct 31, 2006 | 04:54 PM
mikem29ss's Avatar
It is either the resistor or the switch. A resistor can still be bad yet work on other speeds. It is worth checking it w/ a DVM. Good luck
Old Oct 31, 2006 | 04:58 PM
sickmen's Avatar
Thanks, Mikem29ss.
Where exactly is the resisor located?
Old Oct 31, 2006 | 06:02 PM
7jackmack's Avatar
beneath glove box, towards right . When my resistor went bad, it
also only stopped running on only speed 1.
Old Oct 31, 2006 | 06:48 PM
mikem29ss's Avatar
If you remove it, you will probably see where it is broken. Some are a circuit board and you can see it burnt, others are coils and can see them.
Old Oct 31, 2006 | 08:46 PM
1996blackmax's Avatar
When mine was going out it was the dial/switch. I went to the junkyard and picked one up.
Old Nov 1, 2006 | 11:54 AM
MOHFpro90's Avatar
Well, when I get a new climate control, I will be glad to give you my fan speed switch. Still works...its worth trying since I'll give it to you. Then, if that doesnt fix it...then you know its the resistor or something else.
Old Nov 1, 2006 | 12:04 PM
sickmen's Avatar
Thanks, MOHFpro90... it's very generous and I would be more than happy to pay for the S&H.
Please E-mail me at kwelhand@Yahoo.com whenever you done with that part.
thanks
Old Nov 1, 2006 | 01:51 PM
sagres74's Avatar
Oddly enough, I have the exact same issue. Except that mine only works in setting #4. I've taken the whole center dash apart; disassembled the actual dial, cleaned it, put it back in w/ no luck. I'll have to check the resistors next. I'll let you know the results.
Old Nov 1, 2006 | 02:00 PM
sickmen's Avatar
You need to change the resistor... becasue #4 setting does not use the resistor.
Old Nov 1, 2006 | 02:20 PM
sagres74's Avatar
Thanks for the heads-up. It's already pitch black outside so I'll have to try tomorrow or Friday. I'll let you know how it turns out.
trasmadean
Feb 1, 2017 08:20 PM
Finkle
Sep 27, 2015 09:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
BobMax
Aug 15, 2015 12:35 PM
kenc15
Aug 5, 2015 08:29 AM
