Difficulty of a tranny swap?
Old Nov 1, 2006 | 07:29 AM
NCSU_MAX's Avatar
Maximoneypit
Im looking to swap 5spd transmissions with my friend who has a 96 and I was wondering how difficult this may be. Weve done everything from changing out exhaust, suspension (mannnny times), alternators, knock sensors, BBKs, and have a garage full of tools. We also want to swap out clutches and flywheels in the process. Has anyone done this that can give us some advice on the difficulty of this process? thanks
Grant
Old Nov 1, 2006 | 10:47 AM
NCSU_MAX's Avatar
Maximoneypit
bump, i know someone has tried this
Old Nov 1, 2006 | 10:49 AM
Cdg2125's Avatar
I would like to know as well. I'm going to need a new auto tranny soon and need to know if I could swap myself.
Old Nov 1, 2006 | 12:50 PM
pmohr's Avatar
No more Maximas...
Simple, remove axles, shift linkage, electronics, the 3 14mm bolts at the bottom of the bellhousing, the 6(?) 17mm bolts around the bellhousing, starter, trans mount, pull it back and down at the same time to slide the input shaft out of the pressure plate. Remove pressure plate bolts, remove PP and clutch disc, then remove 8 flywheel bolts.
EDIT: I believe matts95max is right, it's 8 FW bolts.
Cdg2125 - that's actually for both trans, that's why I generalized. I only have done an auto on a max myself, the only difference is don't worry about pressure plate/clutch/flywheel, replace with torque converter and flexplate. TC bolts need to be removed before trans removal, bring TC down with it.
Old Nov 1, 2006 | 12:58 PM
f550maranello2's Avatar
werd its pretty easy.. just take ur time an organize all ur tools and parts...
Old Nov 1, 2006 | 01:02 PM
matts95max's Avatar
***when you are putting back together, make sure to thread the *8* flywheel bolts in by hand until and tight. Torque down to spec using fsm. do the same with pp bolts. Dont tighten in a circle patturn.
Old Nov 1, 2006 | 01:29 PM
Cdg2125's Avatar
Is that the same for the auto tranny?
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
