B&M supercooler??
Old Nov 2, 2006 | 10:16 AM
babymac's Avatar
BOOST 4 LIFE!
B&M supercooler??
I just bought and installed a B&M supercooler tranny cooler model #70268. I saw a write up on here about how to install this, but it in the write up they keep using the stock cooler. I found it alot easier not to and was wondering if thats ok to just use the B&M? Will it be enough if I were to say spray some nitrous? Or really beat on my car at the track??
Old Nov 2, 2006 | 11:23 AM
Chunger's Avatar
My other car is a Hybrid
Should be fine to run without stock cooler in the radiator because the B&M should have much greater heat dissipation... but you could also run it AFTER the stock one.
Old Nov 2, 2006 | 01:33 PM
babymac's Avatar
BOOST 4 LIFE!
Yeah, I think I'll redo it tomorrow.
Old Nov 2, 2006 | 09:31 PM
Cdg2125's Avatar
Hey let me know how the install goes. What was the price of the cooler? Im hoping to flush my tranny soon and maybe add the cooler at the same time. Details?
Old Nov 2, 2006 | 10:37 PM
nitink's Avatar
B&M alone is probably 10-15% better than stock cooler, but B&M along with stock cooler is much much better for your tranny. Installation is pain, but I think is worth it.
Where did you purchased B&M from?
Old Nov 2, 2006 | 10:56 PM
Cdg2125's Avatar
It shouldnt be a pain to install. You put in front of the radiator and run the tubes...JEGs has the B&M super cooler.
Old Nov 3, 2006 | 08:03 AM
babymac's Avatar
BOOST 4 LIFE!
It really isn't a pain. The hardest part is where and how you mount the cooler and I got the cooler from a local speed shop.
Old Nov 3, 2006 | 01:08 PM
Cdg2125's Avatar
Cooler should be mounted in front of the radiator so to get the most cold air. Should be able to mount it to the radiator with supports and some padding.
Old Nov 3, 2006 | 02:41 PM
babymac's Avatar
BOOST 4 LIFE!
Yeah I know where it gets mounted , but that's probably the most difficult part about it. And it actually get's mounted to the condenser not the radiator.
Old Nov 3, 2006 | 02:51 PM
Cdg2125's Avatar
Yeah thats what I meant. It wasn't directed at you tho. Directed at nitink.
Old Nov 3, 2006 | 04:17 PM
babymac's Avatar
BOOST 4 LIFE!
Another thing guys , when I had the b&m alone the shifts were smoother. Then when I added the stock one the shifts weren't as smooth until it warmed up.
chernmax
Mar 5, 2018 05:04 PM
nick
May 17, 2009 10:33 PM
Pearl93VE
24
Dec 14, 2006 03:47 PM
deezo
Oct 16, 2002 10:30 AM
Tanman
Jun 7, 2002 09:36 AM
