anyone know how to install headers on 4th gen?
Old Nov 6, 2006 | 07:23 PM
trialt's Avatar
i bought headers and ive actually installed the front one so far.. but im not sure how to get to the one closest to the firewall.. seems too hard to reach..
Old Nov 6, 2006 | 07:36 PM
NYC32798's Avatar
Bump... I'm waiting for my cattman headers and I am going to install them myself. Anyone ever have any problems with the header bolts snapping on them? Mine are pretty rusty.
Old Nov 6, 2006 | 07:43 PM
trialt's Avatar
the front manifold bolts on mine actually came off pretty easy.. they were really clean under the heat shield.. dont know how the back will be though.. so far just changing the front one even made a noticeable difference.. cant wait till i can get to the rear manifold
Old Nov 6, 2006 | 07:49 PM
MaximaSE96's Avatar
Maxima Owner
the car in the air as high as possible.....u might need to take rear valve cover off...i think...get teh FSM and Haynes manual
Old Nov 6, 2006 | 08:05 PM
NYC32798's Avatar
I got the chilton and basically all it says is remove downpipe then remove header bolts. It sucks.
Old Nov 7, 2006 | 01:48 PM
trialt's Avatar
i have the FSM but it doesnt say how to remove that part.. so no one has any ideas how to get to it? =(
Old Nov 7, 2006 | 02:02 PM
MrEous's Avatar
^ Jeff™
hahaha...the rear headers are a major B!tch.
You will need to remove the intake manifold because you will have to get to the EGR tube. You will also need access to the top header bolts.
The rear manifold heat shield is NOT fun either...mainly because it doesn't want to come out.
Good luck...hopefully you, or someone you know, have small hands and can get behind there with no problem.
If I had/wanted to do it all over again, taking out the engine would seem a lot easier. hahaha
Old Nov 7, 2006 | 06:12 PM
VTMaxima's Avatar
Yeah I heard it is much easier to drop the engine. So good luck however you tackle this project.
Old Nov 7, 2006 | 06:34 PM
96sleeper's Avatar
I did mine completely from the bottom, and I did not remove the intake manifold. You need to drop the engine cradle and remove the rear mount bracket from the engine. Some of the bolts are hard to get to, but swivels and gear wrenches are a major help.
VQ'ed
69
Aug 27, 2020 12:29 PM
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
ef9
Aug 27, 2015 07:21 AM
VQ'ed
Aug 19, 2015 04:52 PM
