Crankshaft position sensor or Camshaft...
To make the long story short,
I installed a Fidanza Flywheel some time back.
Since then, i've had a problem with starting up the car.... something about that little sensor on the flywheel not beeing fully compatible with Fidanza Flywheel.. It got damaged during install or whatever..
The problem was minute at first, but now, it's gotten really bad.
I want to change this sensor. I want to buy it today.
I guess I am asking if anybody had the same problem, and which sensor (brand) did you buy to combat this issue?
Not really sure which sensor of the two in title is this?
Thanx for a prompt response.
dont feel bad man, i damaged the signal teeth by accident, and now by car pisses me off because it will just keep cranking and then it will eventually start. But im not going to fix it untill i do the 5 spd swap. Are you sure its not the signal teeth the smaller ring. That is used for alot of stuff such as the idle air, spark, timing, and a few other things.
TallTom
50
07-08-2022 09:54 AM
06-06-2017 02:01 PM
hayne
10-05-2015 11:53 AM
