Stock alarm system rewire question
Old Nov 13, 2006 | 09:21 PM
Russkiy's Avatar
I want to rewire my stock alarm system on 99 max, so instead of hazard lights flashing make the corner lights flash. Should be pretty simple, tried to search but no luck.
Has anyone done it? Any write up Links?
thanks
Old Nov 14, 2006 | 02:28 PM
Russkiy's Avatar
anyone have done it?
Old Nov 14, 2006 | 04:38 PM
Fr33way™'s Avatar
Wild for Width
I have not heard of anyone doing this.
Old Nov 14, 2006 | 04:51 PM
Cdg2125's Avatar
It's not as simple. The wires for the blinkers are wired all the way to the back of the car to the alarm. You would have to cut power from the front blinkers and run the wires from the corner lights to the back of the car.
Old Nov 14, 2006 | 07:39 PM
Russkiy's Avatar
There is a relay in the trunk and i can use power supply from the tails
Old Nov 14, 2006 | 08:05 PM
e_is_chillin
Imma try to help you... Do you own a DMM,test light or a probe? These tools are used to test the polarity of the wires you need
!. Determine the polarity of the hazard light wire used +/-. A positive wire is commonly used... pretty much all you have to do is cut the orignal conection and extend your wire... you can usually find the parking light wire in the kick panel.. it should be a red wire with a green trace.. hope this helps.
2. If this seems confusing maybe its best to let the pros handle it.
Old Nov 14, 2006 | 08:42 PM
Russkiy's Avatar
yeh, i wish it was that simple in there. It is a little more complicated than that.
Appreciate your input anyways.
Old Nov 14, 2006 | 08:56 PM
Fr33way™'s Avatar
Wild for Width
If you know then why don't you do it, then post.
Old Nov 14, 2006 | 09:18 PM
andrei3333's Avatar
i had an aftermarket alarm installed recently on my 97 maxie, the useless corner lights flash now in the front along with the yellow parking lights, but not the headlights
Old Nov 15, 2006 | 09:27 AM
Cdg2125's Avatar
that doesnt matter...If you want the corners to light up and not the bumpers you need to find the wire for the bumper lights in the box and cut it. You need to then get power to the corners from the alarm relays in the trunk.
Old Nov 15, 2006 | 07:34 PM
Russkiy's Avatar
what about locating the the power wire from emergency lights at the actual control unit for the alarm and replacing it with corner lights power? But this sound too easy, i am sure it is more complicated.
Old Nov 15, 2006 | 07:38 PM
Cdg2125's Avatar
Look at the wiring diagram in your manual. I dont think that it works like that. I'm thinking that it all is located with the alarm module in the rear. I'm not sure. Do some searching in the manual and in the car.
rbuswell
Nov 17, 2016 04:54 AM
incubusjohnny
Nov 3, 2015 05:18 PM
kmitchel
Oct 28, 2015 09:46 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Blackwind
Aug 5, 2015 06:35 PM
