Removing screws from stock FPR
Has anyone had any luck with this? My screws appear to be galled, and my attempt to remove the screws while the fuel rail was off the car didn't help much at all, either. Anyone able to do this with seized screws? If so, how? Has anyone been able to do this with the fuel rail still in place and installed?
I took a dremel to the screws and made a flat grove in the head of the screw so I could get a Flat Head Screw driver on it. It took a LONGGG time but I finally got it
-matt
-matt
Anyone manage to do any of this while the fuel rail and FPR were still installed? If so, you are my hero, and please explain how, because removing the damned upper intake manifold is a *****...
If the visegrips don't work while in the car, then a proper set up with an impact driver (a screwdriver that works by striking it with a hammer) and that will do it. A little PB Blaster helps a lot too.
I have yet to see a truly galled fastener. Auto mfrs are careful to avoid situations that cause true galling. But I have seen them damn hard to get apart.
Dave
Dave
The Frye
Sep 2, 2021 11:03 AM
x1000
