Fuel Filter Replacement Question
Good morning
So... I decided to change my fuel filter yesterday along with the spark plugs in an attempt to improve my gas mileage. Spark plugs were ok, but I ran into a problem with the fuel filter and would like suggestions.
After removing the fuel pump fuse, depressurizing the fuel system, removing the two hose clamps, getting the filter out of the bracket I was totally unable to pull the hoses out of the filter. I tried cranking again several times to make sure there was no pressure in the fuel lines, still nothing.
Any suggestions (beside a blow torch
![flame](https://maxima.org/forums/images/smilies/flame.gif)
Don't just pull, twist. I ran into the same problem when replacing my crappy old filter with a z32 filter. Forceful twisting action will remove the hose as though it has threads, slowly but surely. Good luck!
Did you really just say that you were going to use a blow torch? On your fuel filter?! I hope you were kidding. Use a flat head and pry the hoses off. If not the cut the hoses with a blade and install the new filter. Simple.
Thanks all for the replies, I'll try that this morning!
Yeah - that was a joke.
hoses are stuck on there pretty tight in general, so it's not always due to residual pressure in the lines. Like it was stated before, either twist it off slowly or use the inching method by applying force to opposite sides of the hose opening in an alternate fashion. I used a little WD40 which helped to loosed things up a bit (I know this isn't it's intended use, but it worked) since it wicks into the space between the nipple and the hose. best bet is to take the top hose off first using the inching method and then twisting the FF off the bottom hose. I don't recommend cutting the hoses, they're already short as it is. Patience!
Originally Posted by 99se5speed
Do you guys by any chance know that part # to the z32 fuel filter? If not then the filter from a 95-96 300zx Non-turbo would work?
I changed my fuel filter today. Yes the twisting plier method definately works. You really have to try to start the car and take off the gas cap to relieve as much pressure as you can. I knew after i loosen the clamps there is no freaking way those hoses will come off by pulling on them. I immediately knew this is gonna be a b***h to get off. Patience really is key.
Originally Posted by pocketrocket
16400-N7605JP is the one I bought, it is listed for a 300ZX.
Thanks. I was told today by my friend who has a z32 fuel filter in his car that he bought the 95 300zx twin turbo one and it works perfectly.
Hey all, seems like quite a few members decided to change their fuel filter and since I received few PMs with questions on how to do it, I thought I'd post the link to the DIY I used:
http://vbxmaxima.8m.com/fuelfilter.html
Have fun!
Have fun!
homewrecker
08-24-2015 08:56 PM
MaximaDrvr
08-19-2015 08:20 PM
kirkhilles
08-08-2015 10:53 AM
