Tranny rebuild Kit on ebay
Just wondering if this a good rebuild kit ... or if I can get something better elsewhere .... I'm not knowledgeable about this ... thanx in advance for your suggestions ...
http://cgi.ebay.com/ebaymotors/ws/eB...m=280009864626
Ali
Ali
Originally Posted by nguyen925
yeah ebay..not so trustworthy..SELLING THINGS ON EBAY IS GOOD BUYING NOT SO GOOD.
Originally Posted by GoalieKeg
Your nissan dealership. I'd only go OEM for tranny parts.
That's a perfectly acceptable kit. Transparts is a reputable aftermarket rebuilt part supplier. The price is pretty good.
I have a couple of questions about the details of that kit. 1) the photo is for an LSD kit because it has the monster driver side diff bearing, but the item desc is for the non-LSD tranny 2) the application dates (91-96?) don't make sense to me. I know that the synchros changed a little in 96, but I'm not sure that the 3rd gens are absolutely identical in bearings, synchros, and seals. I would expect it to be more like 94-96. Just make sure that you get the correct kit.
While I haven't bought a Transparts kit before to confirm this, every rebuild kit I've seen thus far, including parts from Nissan, are made with the same brands of bearings. The only difference I've seen is that my kit supplier uses an SKF for the mainshaft bearing instead of a Koyo, and both are high quality brands. The diff bearings, for example, are ALWAYS made by NTN since these are a special size. The seals you get might be a little more generic, but since 99% of all sealing problems come from the seal installation or bearing play, I don't believe quality is an issue.
Not sure if it's worth buying the synchros. Usually the synchros aren't too bad, and if they are then replacing them doesn't fully solve the problem anyway due to damage of the hard parts.
Really, the biggest factors in a good tranny rebuild is the condition of the original hard parts, the cleanliness and installation techniques, and proper measurement for the shims. The last two are not easy to achieve as a DIYer.
David
David
David
David
Originally Posted by alleydawg6
thanx alot for the clarification man ... but do you have a better place I can go to buy a rebuild kit?
I can say buying from Nissan will be more difficult and more expensive for very little, if any benefit.
Dave
Look under Transmission Parts in your local yellow pages, I called a number of places nationwide (from internet searches) then called someone local and got about the same price. He also sold rebuilds much cheaper than anybody else I could find, just wish I would have known that before I ordered/paid for the bearing kit.
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
pktaske
Sep 4, 2015 08:40 AM
