Shim rear wheel?
Old Nov 22, 2006 | 07:01 PM
Dexter's Avatar
Shim rear wheel?
I went to get an alignment and I was told that the rear left wheel couldn't be adjusted and my only option is to get it shimmed down into spec (it's at 0.28% right now) has anyone else heard of this, why is this the ONLY wheel that can't be adjusted? Am I being set-up for a scam? i'm told 80 bucks to get it shimmed.
Old Nov 22, 2006 | 07:29 PM
RA030726's Avatar
I'm nutty for Nissans
Whats that # for, camber? toe? caster? The rear beam cannot be aligned since there is nothing to adjust. It can be bent, but thats usually done to set the toe for road racing and auto cross. The bearings could be bad and cause some play. I have never heard of shimming but I guess one could shim where the hub bolts to the beam.
Old Nov 22, 2006 | 09:27 PM
Dexter's Avatar
that's for the left rear toe, all the other tires are aligned exept that one.
Old Nov 23, 2006 | 07:30 AM
RA030726's Avatar
Well if its truely out of spec and they can fix it, $80 aint that bad.
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
stromm
Aug 27, 2015 04:13 PM
twotonezed
Aug 16, 2015 11:41 AM
