A- pillar and headliner removal
Old Nov 27, 2006 | 04:18 PM
TurTLe*'s Avatar
I'm looking to remove driver side A pillar to peel down the headliner to run some wires.
From what it looks like the A pillar is directly pull out, most likely held on by some tabs and clips and i can pull the headliner simply removing the visor.
I just need someone to confirm this.
Old Nov 27, 2006 | 04:28 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Pretty sure hte pillar just pulls off like you said. But, the headliner doesnt just peel down like you said. It has a cardboard backing and is more stiff than you think. If you are too rough with it you can tear or crease it. What are you trying to run?
Old Nov 27, 2006 | 04:47 PM
TurTLe*'s Avatar
a couple of wires from my Bluetooth kit and a radar detector wire
Old Nov 27, 2006 | 05:23 PM
Vlasic's Avatar
OH, for some reason I invisioned you wanting to run wires accross the entire headliner instead of just the corner. Dont know how I thought that. You should be able to pull the headliner down a little bit, but do be VERY careful.
Old Nov 27, 2006 | 06:20 PM
TurTLe*'s Avatar
oh no. I've done that before on other cars as well. I knew there was a lot of bolts and screws behind random things and hidden stuff as well. I just needed someone to say " oh yea i've done that before and there isn't anything hidden"
Old Nov 27, 2006 | 07:00 PM
RA030726's Avatar
I'm nutty for Nissans
Pop the A pillar off with a pry tool/flat head. The easiest way is to tuck the wire up near the windshield then down the a pillar.
Old Nov 27, 2006 | 07:56 PM
TurTLe*'s Avatar
thanks John, that was my orginal thoughts. I have trim prying tools just wanted to make sure it wasn't held on by anything weird cause i gave a tug on it and it didn't budge at all.
Old Nov 27, 2006 | 08:53 PM
PhillyDonut's Avatar
I would like to take my headliner off to track down some squeaking around the moon roof!!!
my03maxima
Jul 28, 2024 07:40 AM
chisam14
Nov 6, 2018 08:56 PM
jonreidhead
Jan 6, 2016 09:38 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
