How do I put "Cruise Control" on this steering wheel?
Old Nov 28, 2006 | 03:02 PM
'90_Maxima's Avatar
Anyone know how I can put cruise control on this steering wheel?
I don't mind electrical wiring, it's hacking into this steering wheel that I want to avoid. It is going in a 3rd gen w/out an airbag, and I don't care about hooking that part of it up. I just want the cruise to work and have that factory look. Thanks in advance.
Old Nov 28, 2006 | 04:38 PM
Cdg2125's Avatar
Well you need to hack it if you want it on the wheel. Why not mount it somewhere else?
Old Nov 28, 2006 | 04:51 PM
'90_Maxima's Avatar
I'd kind of like for it to look factory. The standard wheel in it already has the cruise mounted in the steering wheel front cover (not beside it as this one would be) and I was considering mounting the old buttons in the center console, but that'll be the last resort. I'd much rather hack this one up and wire it up with the existing wiring. Which model of steering wheel mounted cruise control switch would work and where would I need to hack it up at?
Thank you very much for your reply!
Old Nov 28, 2006 | 04:53 PM
Cdg2125's Avatar
well the 4th gen with cruise control will work I believe. Should wire up the same as long as your 3rd gen has it. Need a different wheel hub I think tho.
Old Nov 28, 2006 | 05:32 PM
MaximaSE96's Avatar
Maxima Owner
the cruise pod will go on the right hand side of the steering wheel where that cap is
Old Nov 28, 2006 | 07:29 PM
'90_Maxima's Avatar
That's exactly what I was hoping for. Could you show me a pic of the "Cruise Pod" that I will need for this type of steering wheel? Or give me a year/make for the cc switch I need?
My guess is that this one will not work...
It's the only later model switch pic I could come up with, so help identifying this will really help.
Thanks for the help so far.
Old Nov 29, 2006 | 06:44 AM
95mtlMAXSE's Avatar
shift_Puff
that switch you have there is for 95 96 models, the buttons for 97-99 are the ones you need, because your steering wheel is from a 97-99. The connections should be straight forward as it was an option for the car
Old Nov 29, 2006 | 06:49 AM
'90_Maxima's Avatar
Moochas!
Old Nov 29, 2006 | 07:41 AM
1FSTMAX's Avatar
why not get an nicer leather wrapped steering wheel out of a 97-99 maxima, or other nissan?
Old Nov 29, 2006 | 10:13 AM
Cdg2125's Avatar
Yeah I'm trying to figure out how to put the 00-01 wheel in my 98. Can't find the links for doing it. Anyone know?
Old Nov 29, 2006 | 10:48 AM
HomerMAC's Avatar
Donating i30 Owner
im thinking the cruise from teh 97^ 4thgen should work....
you have to use the corresponding clockspring... so the plug is there
Old Dec 22, 2006 | 10:22 AM
Jbizzysc's Avatar
HOw do I start my own post it won't let me?
trasmadean
Feb 1, 2017 08:20 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Maxima_Joe
Oct 15, 2015 08:01 PM
tnewbs
Aug 28, 2015 10:15 AM
Flores94
Aug 13, 2015 01:17 PM
