Exhaust system
Old Dec 2, 2006 | 09:10 AM
MikeB's Avatar
Exhaust system
I know my precats are questionable, as they have the 'rattle'. My muffler has lost at least one wrap layer now, so it will be time to replace soon. I don't think I want to go the y-pipe route, but want some more performance. Will the precats hammer my main cat if they plug ? Are pre cat replacements available at reasonable cost ? Car sees a fair amount of moisture (WA . state)
Old Dec 2, 2006 | 10:54 AM
Cdg2125's Avatar
So you want performance and you say you don't want to go y-pipe? Y-pipe is an extra 20hp (approx) Why would you not want a y? And what precat are you talking about?
Old Dec 2, 2006 | 11:24 AM
CRiME's Avatar
oem ftw!
I was thinking the same thing, why don't you want a y pipe? the difference is def. noticeable. if you're worried about it being too loud, you shouldn't be. I added a Budget y pipe and even threw in a high flow cat, kept the stock b pipe, resonator and muffler, the car still sounds stock and has much more power. You really have nothing to lose by adding a y pipe, esp. if your precats are bad.
Old Dec 2, 2006 | 11:44 AM
Cdg2125's Avatar
I dont think it's worth doing any performance mods if you wont get a y pipe. Why waste money on more stuff when you could add 20 right away? I feel stupid as is doing my 00vi before the y-pipe, but o'well it'll come in a few months. Almost like when I saw a guy on cardomain in the process of adding turbo to his max and he was selling his y for more money.....turbo the car with a stock exhaust? Smart huh? lol
Old Dec 2, 2006 | 12:13 PM
Sy0p's Avatar
give me y-pipe or give me death.
Old Dec 2, 2006 | 04:06 PM
markd248's Avatar
hahah nice.
yeah definatley get a ypipe they dont have precats, therefor you dont need to worry about the two precats on the stock pipe. i think everyone just about agrees that y-pipe is the 1st or easiest mod to do. so do it! im hopefully getting one soon.
Old Dec 2, 2006 | 05:00 PM
Max_Out's Avatar
Under the radar
i have a quick question related to the y-pipe and the cat. right after i got my y-pipe installed and took off i noticed a rattle sound right around the cat area, it sounded like a bolt being rattled around in the sat housing... needless to say i was alittle freaked. it has since never happened again, but what was it??? i know it wasnt a bolt because i helped my mechanic install it and know for sure it was clear of any debris before install.
Old Dec 2, 2006 | 10:46 PM
Cdg2125's Avatar
Could have been anything stuck up there. It doesnt do it now, the pipe works fine, so don't worry about it.
Old Dec 3, 2006 | 12:17 AM
Apparition's Avatar
Ichiban King
Yeah until his car explodes.. Compliments of Nissan. One day the problem is there and then you don't notice anything for a while and then all of a sudden it ends you.
J/K, my car has had some strange noises and none seemed to result in harm. "Odd," some would say.
Old Dec 3, 2006 | 06:53 AM
nexgenmax's Avatar
R34
Y pipe is the best investment
Old Dec 3, 2006 | 01:19 PM
tchambers's Avatar
The y pipe does have precats on it. The after market y pipes dont have those which is what makes them flow better and add that est. 20 hp. and i dont think you can just replace the pre cats.
Old Dec 5, 2006 | 10:07 PM
MikeB's Avatar
Thanks for the good advice- looks like the budget y pipe and then look at a good muffler in the spring.
Old Dec 5, 2006 | 10:22 PM
f550maranello2's Avatar
make sure u get a oem muffler if u dont want it to sound gay....
Old Dec 5, 2006 | 10:32 PM
2da mizzax's Avatar
i hope a tree falls on all of you air polluting Y-Pipers!!!!
Old Dec 6, 2006 | 03:22 PM
Max_Out's Avatar
Under the radar
the main cat is still there so you will only pollute for a little while unlike the diesel trucks runnin around these days. if your so concerned with polluting 4th gens you should go big and take on nascar emissions lol j/k.
Old Dec 7, 2006 | 11:16 AM
2da mizzax's Avatar
ok os i was joking about the trees. but........... i have the chance to get a stillen y-pipe for $100. if i change that but leave everything else stock (cat, b-pipe and muffler) will it be much louder? i heard stillen has a problem with the bees in the can sound. still so?
Old Dec 7, 2006 | 12:13 PM
CRiME's Avatar
oem ftw!
I can't speak for the stillen, but... even with the addition of a warpspeed high flow cat, my exhaust basically sounds stock. I still ahve the stock B pipe, resonator and muffler. I have a Budget Y, but i imagine the tone would be more or less the same regardless of manufacturer. It's a little more deep when cruising btwn 1500 and ~2X00 RPM's, but it's barely noticeable. Also, the deeper tone might even be because of the high flow cat. But if you can get that for $100 I would def. give it a shot
Old Dec 7, 2006 | 10:15 PM
LiGhtSoUt's Avatar
get a ypipe ucan get it for cheap and you'll feel the differnce you can change everythign else cat and bpipe but stick with the stock muffler if you want it quiet
Old Dec 7, 2006 | 11:12 PM
Fr33way™'s Avatar
Wild for Width
He could not use the aftermarket y anyway with a turbo setup. Most turbo setups use a reverse y that feeds the exhaust back to the engine bay where the turbo is mounted and then back out of the engine bay to the b/muffler. If you look at any of the possible places to put a turbo it would make sense.
Old Dec 7, 2006 | 11:17 PM
Fr33way™'s Avatar
Wild for Width
The rattle could also be the flex section.
Old Dec 7, 2006 | 11:20 PM
Fr33way™'s Avatar
Wild for Width
Precat just aft of one of the turbos on a 300ZX VG30DETT:
Old Dec 7, 2006 | 11:24 PM
Fr33way™'s Avatar
Wild for Width
C5 Corvette precats:
Old Dec 12, 2006 | 03:24 PM
ckymaxx's Avatar
so do u still need pre-cats if u have a cali spec max? My whole system is rusted and rotted and need to replace everything.
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
