Wow i need help real bad!
Old Dec 3, 2006 | 05:50 PM
Luisjo's Avatar
So, yesterday i was driving and noticed withe smoke coming from around the right tire (front) almost unoticable i noticed it a bit, so im on the highway and from nowhere this mitsubishi mirage comes in and tells me to run.. so i did and flored it then he wins by like a mile! when i come to a stop i noticed a CLOUD of white smoke coming from the same tire (front right) and i got scared almost pulled to the side of the highway but i went on so it stoped for after 5 to 10 minutes when i oppened the hood nothing seemed out of place im just scared i didnt damaged it, can someone tell me what does it have wrong?? thanks. another thing the car seemed to stuck at 85 MPH dont know if it has something to do with it its a 1995 nissan maxima GLE automatic thanks
Also i installed the LEDS on the whole car (except whe it says in what gear youre in) and tried to change the milage and "broke it" dont know it just wont read miles any more (even the "trip" milage) i tried to move it by force.. could someone tell me how to fix it?
Old Dec 3, 2006 | 05:58 PM
Wassup2114's Avatar
It's really hard to understand what you're saying. From what I got it sounds like your caliper might be sticking, causing the brake pads to overheat and smoke. The lack of power could be a number of things. I'm not sure what you even mean in your second question, LEDS? Light Emitting Diodes?
Old Dec 3, 2006 | 06:00 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Check your coolant level and power stearing fluid level. Maybe you have a leak and its dripping on the exhaust?
Old Dec 3, 2006 | 06:19 PM
Luisjo's Avatar
yes LEDS its another question about the thing that tells you the milage of the car i broke it and dont know how to fix it... srry for my english its not my natural language
Old Dec 3, 2006 | 06:26 PM
Luisjo's Avatar
i read that theres is something in the computer that doesent let the car pass a determine MPH is that true?
TurTLe*'s Avatar
you need to speak understandable english. Unnoticble but you noticed it a little? huh ?
you raced a slower car then you and you got smoked by a mile and then you stoped and you saw smoke on your right front side. did you look at the caliper? first thing is to look at brakes and if nothing is wrong with them, confrim that the problem is still happening.
LED are another problem, forget the dumb LED's for now since your car is more important.
Old Dec 3, 2006 | 06:51 PM
BlackMaxdout's Avatar
I raced a Mitsubishi too! And I saw white smoke too! But it was his car breaking down.
I bet when you installed LED's into your gauge cluster, you either dribbled solder, or messed up a connection somewhere. This would prevent your odometer (the mileage thing) from working properly.
Old Dec 3, 2006 | 06:58 PM
the_3d_man's Avatar
are you saying you tried to roll back the milage on your odometer?...
check your brakes. put your hand on the right brakes and if they are hotter than hell, you have a seizing caliper. (compare it to the left side though, cause if you were just racing and braking hard they would be hot as hell anyway)
Old Dec 3, 2006 | 11:09 PM
aznprid972's Avatar
I wouldn't check it like that but that's ONE way...
Old Dec 4, 2006 | 01:16 PM
Luisjo's Avatar
I just noticed that theres a oil spill around where the smoke was coming out so is it a possibility that the withe smoke could be because at those speeds the oil could just leak or something?
Old Dec 4, 2006 | 02:02 PM
Vlasic's Avatar
^wtf?! Yes, at speeds over 80mph the engine seals break down and oil starts leaking out. At 100mph the engine can explode so be careful.
Since there is a oil leak, that probably confirms what I said above.
Old Dec 4, 2006 | 02:27 PM
Luisjo's Avatar
So... what youre saying is that an oil seal broke down and that maybe the reason that the white smoke came out? then i will check that out.
Old Dec 4, 2006 | 02:31 PM
Vlasic's Avatar
omg, no. What kind of oil is it, motor oil, trans/gear oil, power steering/ATF oil? is it even oil, or is it coolant? Is it leaking from the right side? You need to get under your car and find where the oil is comming from. Its probably a power steering leak or a coolant leak and its getting on the exhaust and burning.
Old Dec 4, 2006 | 03:06 PM
Wassup2114's Avatar
He said it's coming from the right front tire. How would it be dripping on the exhaust?
Old Dec 4, 2006 | 04:38 PM
Vlasic's Avatar
Oops, for some reason I was thinking of a RWD setup.
Either way, he says he has a leak and smoke. It is very possible that what ever is leaking is hitting a hot surface.
Old Dec 4, 2006 | 05:08 PM
Luisjo's Avatar
yes the MOTOR OIL its dripping on the manifold (beneath the hole where you put the oil)
Old Dec 4, 2006 | 05:11 PM
Vlasic's Avatar
Probably need to replace your valve cover gasket. Its easy and the gasket is cheap. If you can take a picture that would help us confirm.
chisam14
Nov 6, 2018 08:56 PM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
Andy29
Sep 29, 2015 05:32 AM
