Start up squeak
Old Dec 6, 2006 | 05:47 PM
RKZ's Avatar
RKZ
Start up squeak
Since the colder weather has come i've been getting a strange noise from my driver side part of my engine bay. It sounds like a belt squeaking, but i know the belts are on the other side. Could it be the starter or anything, its rather annoying and it only lasts during start up?
Old Dec 7, 2006 | 06:30 PM
RKZ's Avatar
RKZ
bump
anyone?
Old Dec 7, 2006 | 06:41 PM
2da mizzax's Avatar
what grade oil is in the car? car crank a ton of times before starting up? does the sound go away?
Old Dec 8, 2006 | 08:31 AM
wlaukaitis's Avatar
I have this too. I changed my belts because they were pretty shot. Does it squeak when it is "overnight" cold? My squeak has changed pitch but it has not gone away. I think it is the A/C - Alt belt.
I did notice that my idler is very worn.
Old Dec 8, 2006 | 10:02 AM
shilov's Avatar
Just try tightening you drive belt tensioner. If the squeak goes away then here is you problem. If it doesn't turn it back the way it was. Something else is squeaking.
Old Dec 8, 2006 | 12:11 PM
2da mizzax's Avatar
how can it be a belt when he says "it is coming from the drivers side part of the engine"?
Old Dec 8, 2006 | 12:31 PM
deadmax96's Avatar
try ur starter!! i kno it might sound out of the norm but my 96 squeaked everytime i started the car than i replaced it and bingo no more squeaking..
Old Dec 8, 2006 | 12:50 PM
alleydawg6's Avatar
Livin dreams thru his Maxima
... I had the same squeeking noise ... I replaced my starter and it's gone now ... hope that helps ....
Ali
Old Dec 10, 2006 | 08:35 AM
RKZ's Avatar
RKZ
i'm sure its not my belt so ill have my starter check out, thanks!
Old Dec 10, 2006 | 10:46 AM
MOHFpro90's Avatar
I would just regrease it. Saves you $100+. Sure, it took longer, but for an hours work, saving $100 is worth it IMO. And besides, working on your car is fun, right? :P
Old Dec 10, 2006 | 03:29 PM
wlaukaitis's Avatar
You're right, my starter does the same thing when it is cold out. I realized what you were talking about when it did it friday night. It has been doing it since I got the car in late 2002. It sound like a bad/un-lubed bearing.
I am going to do nothing about it. starter works, who cares.
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
SusieQQ
Sep 9, 2015 12:14 PM
trungg86
Sep 4, 2015 04:58 AM
