How long does it take to install Ypipe?
It also depends on if your bolts are rusted or not?
If they are rusted I suggest you go to a local exhaust shop and have them remove them and put new ones one, this way when you go to install the pipe on sat you won't have to worry about anything...
Took me about 2 hours the first time. If you live in a snow state and you don't have an impact wrench, have a shop install it.
Recommended: Liquid Wrench penetrant, swiwel socket and lots of extensions.
problem isnt breaking bolts, just do not break any studs on the exhaust manifolds! wd40 and use torque specs from the fsm. I believe Y pipe to exhaust man – 31-35 ft/lbs u can check to make sure. gaskets from autozone too! round ring like crush gaskets
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
