Where to buy a cheap Timing Chain Kit
Cause my maxima's timing chain make more and more noise, finally i make up my mind to change it. So here is the thing, i quoted the price in several local store, they told me they don't have the kit to sell, they just have the whole part, that will cost about 1,000$. Does anyone know where can i buy cheap kit, 1,000$ is too much for me. I am in canada, so pls give me some place which they can mail the kit to me. Thanks a lot
umm the vq in my maxima definately has a timing chain..just like the one I had before and the other 2 in my driveway. I have 2 spare motors. I have whatever timing component you need. If it is making noise, it is most likely your tensioner/guide (whatever its called) inside the case. it is like a $50 part at nissan new. There are many threads on this, just do a search on google for it.
Originally Posted by Maverick7687
IIRC the VQ has a timing BELT.. I know my VQ makes no noise where my KA (240sx) you can definately tell it has a chain. Not too sure though as I have never had one apart.
Here you go.
if your engine has high miles, i would recommend just getting a low mileage engine
http://cgi.ebay.com/ebaymotors/Nissa...spagenameZWD1V
Thats a kit
http://cgi.ebay.com/ebaymotors/1995-...spagenameZWD1V
This si just a chain
Thats a kit
Originally Posted by bklynzsleepy
THE VQ RUNS ON A CHAIN NOT A BELT!!!
right... $1000 for a kit you got quoted?
That is extremely on the high side, because i just did a VR6 timing chain, tensioner, sprokets and guides. All OEM VW parts came out to be $1200 thats with sprokets on the cams, intermidited and crank. upper/lower chains and all the tensioners as well.
That ebay one linked about is a fair price but not sure on how the parts are. THere shouldn't really be kits out there as not too many require repairs. If a tensioner or guide has fail people normally replace that one. Some people replace everything to be on the safe side since your already in there. But normally most shops replace whats broken.
http://www.courtesyparts.com/A32_tckit.html
you can replace the tensioner in a few hours....there is a great write up on the water pump replacement and it basically tells u how to change the tensioner since it has to be taken out anyway...but u obviously dont have to replace the pump...although its not a bad idea
Originally Posted by NmexMAX
Originally Posted by Papa Squat
buy another engine with lower miles. its easier and takes less time.
SmokinMax02
18
Sep 11, 2015 12:25 AM
MikesChevelle
Aug 6, 2015 11:36 AM
[/IMG]
