Diagnosis Request: Drivetrain Sound and Vibration Through Gas Pedal
Old Dec 11, 2006 | 07:19 PM
Sloppy Snood's Avatar
PROBLEM: My 1997 I30t (175K miles) has a vibration that is audible from the interior and felt through the gas pedal when driving. In particular, the sound is not a "click" like worn CV shafts. It increases in intensity as my speed increases but it nearly ceases when I harder into turn right hand turns.
ITEMS REPLACED "RECENTLY:" I replaced the CV shafts 6 months ago with NAPA re-grinds and replaced the front brake pads yesterday. Wheel bearings have not been replaced, CV boots show no sign of damage, and all bushings on suspension look fine (all Energy Suspension replacements for '97 Maxima 1 year ago) as do the shock mounts (no play).
QUESTIONS: Is this typical of a wheel bearing problem? Bad re-ground CVs (no clue what the life expectancy is on a NAPA re-grind; yes, I know. Buy some Raxles. I intend to Raxle after all else is checked and eliminated from possibility.)
What can you suggest I check/replace (or think the problem is)?
Thank you .Orgers! - Slopster
Old Dec 11, 2006 | 09:23 PM
KINGMAX's Avatar
what kind or sound is it?
Old Dec 12, 2006 | 01:42 AM
deadmax96's Avatar
sounds like the wheel bearing. see how much play you get when you shake the spindle without the tire and rotor on....if you have too much play than it needs to be replaced...unless you have a press lying around you will have to take it to the shop. had to replace mine on my 96 max
Old Dec 12, 2006 | 03:30 AM
Sorry KingMax.
The best way I can describe the sound is a sound with pitch, tone, and intensity varying with the car speed. To me, it sounds similar to the sound a playing card makes when flapping on bicycle spokes.
Similar to a Gieger counter but not a formal "click" sound (as with CV shafts).
Slopster
Old Dec 12, 2006 | 03:57 AM
I'll pull the front tires/rotors tonight and take a look. I have the Nissan Service Repair manual on CD so I am going to see what it says regarding the wheel bearings as well. Thanks deadmax96.
Anyone else have other possibilities or items to check?
Old Dec 12, 2006 | 04:02 AM
dgeesaman's Avatar
Maintenance Monster
Take it to a good alignment shop and pay them for a 30min diagnosis.
I suspect it might be the wheel bearings, but an experienced mechanic can give a real diagnosis.
Dave
Old Dec 12, 2006 | 04:09 AM
Dave
Thanks Dave. I will do that over lunch. I really appreciate the replies guys. Thank you. -Slopster Out.
Lilfatz301
Sep 18, 2015 08:06 AM
Maxxx10
Sep 13, 2015 03:16 PM
jcvgn
Sep 10, 2015 08:03 PM
slowlifer
Sep 8, 2015 05:53 AM
TheMafia
Sep 4, 2015 08:26 AM
