A light thunk right when I shift...
Old Dec 11, 2006 | 09:01 PM
ComradeJew's Avatar
And yet another oddity!
Suppose I am in neutral at a light - I will engage the clutch, grab the shifter and as I start shifting into first I'll hear this faint "thunk"; it'd shift fine, drive fine, and I don't hear it when shifting... only when I am stopped and even then its very faint and does not happen all the time... maybe 4 out of 10 times... ideas?
Old Dec 11, 2006 | 09:04 PM
urmab's Avatar
Now im not sure at this but I think this might be a trowout bearing
Old Dec 11, 2006 | 09:10 PM
ComradeJew's Avatar
It's a brand spanking new one; it used to do that before I did the clutch swap. Also, the TO bearing is clutch activated, now shiftter activated.
Old Dec 11, 2006 | 09:23 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Play around with the shifter, shifting in and out of gears with the car off and without pushing the clutch pedal in. Does it still make the sound?
Did you install your STS yet?
Only thing I can think of is that you messed up on something when putting your shift linkage back together, either at the shifter end or the transmission end.
Old Dec 11, 2006 | 09:46 PM
ComradeJew's Avatar
Hrm I'll try that.
Though we double checked everything and as I mentioned before - the sound was there before I installed the STS.
Old Dec 12, 2006 | 07:02 AM
90stanza's Avatar
This happens to me also when I try and shift into first at a light sometimes. I just wait and then try and shift into first agian and that seems to work.
Old Dec 12, 2006 | 07:22 AM
99se5speed's Avatar
SHIFT_up
i was going to say it's because of your STS but since you had the problem even before that and everything is fine, i wouldn't really worry about it until something really really serious happenes.
Put in a urethane shifter bushing and believe me you'll totally forget about that sound and focus more on the sound of precise shifts.
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
