SC idler pulley woes -->
Old Jul 2, 2001 | 10:00 AM
Matt_P
I actually have one of the last V1s, before stillen switched over to using the V2s. Overall, the supercharger itself is pretty quiet. However, the idler pulley is screeming(not like a belt squel, more like bearings) and not running efficent. Has anyone else had this problem? Was it covered via the SC warranty? Whats a good replacement pulley? I have to get this fixed asap because the belt is getting ready to go.
Also, don't go to Autogear. They suck. When I called them to have this fixed under warrant, they said they no longer support any supercharger kits!!!
Matt P.
Old Jul 2, 2001 | 10:20 AM
JimW
You may want to shoot Jose a message-->
Matt P.
He's had more than his share of supercharger experiences, he may be able to point you in the right direction.
How's it goin' Matt? Haven't heard/seen you in ages..
Old Jul 2, 2001 | 10:52 AM
Matt_P
Re: You may want to shoot Jose a message-->
Hey Jim,
what's up.
I sent you a PM.
Matt
Old Jul 3, 2001 | 01:40 PM
Matt_P
New pulleys ordered -->
I ordered new pulleys from stillen. I asked Dean whether these were those cheap plastic ones that keep failing. He said these are some high tech spaceage polymer that is supposed to withstand much higher temperatures. I ordered both idler pulleys. Only one is bad. I just figured that I would replace both in one shot.
Is he bs'ing me? Can anyone confirm that they have replaced those problematic plastic ones? I do need to put these on quick though.
Matt P
Old Jul 3, 2001 | 01:45 PM
mzmtg's Avatar
Minister of Silly Walks
Re: New pulleys ordered -->
Matt P
high-tech-space-age-polymer = cheap plastic
plain aluminum = durable pulley
Old Jul 3, 2001 | 02:12 PM
redmaxpa007's Avatar
i SeE what you did therE
Try and get in touch with phil... he went thru this ....
Old Oct 4, 2001 | 10:04 AM
jgadlage's Avatar
It's not the pulley itself that is failing it is the bearings
You all can get an upgraded pulley made out of aluminum, but unless the pulley is shattering then you are not fixing the root of the problem. It sounds like it is the bearings inside the pulley that are going bad and not the pulley itself. Unless you can fix the bearings you are attacking the wrong problem.
James92SE
142
Jan 2, 2024 09:23 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
