o2 Sensor Question
Old Dec 13, 2006 | 07:18 PM
NCSUpilot's Avatar
o2 Sensor Question
I just got a CEL (0303 left front), i had this come up about a year ago, but it went away. Recently, I have noticed a drop of about 4mpg. Would you recommend replacing all three sensors at the same time, or just the front two or just the one that gave the error. Is it true that downstream sensor DOESN'T effect gas mileage?
thanks,
Old Dec 14, 2006 | 03:09 AM
NCSU_MAX's Avatar
Maximoneypit
I would replace both since you have a 95 if you havent had them replaced already in the recent past. 95-96s only have 2 O2 sensors whereas the 97-99s have a third behind the cat. Only case I believe your mpg would not suffer is if it were that third one behind the cat on a 97-99. BTW, Go State!
Old Dec 14, 2006 | 05:39 AM
dallas0593's Avatar
This is not true, 95-96 also have 1 by the cat as well.
Old Dec 14, 2006 | 05:52 AM
dralucard's Avatar
Definately replace all 3 sensors, especially if you have high mileage. You'll change 1 and then 2 months later another one will take a ****e.
Old Dec 14, 2006 | 09:18 AM
NCSU_MAX's Avatar
Maximoneypit
Thats right, I forgot they had one in the cat as opposed to behind it. Been awhile since Ive been under a 95-96
Old Dec 14, 2006 | 07:16 PM
MDeezy's Avatar
if the other sensors are functional why replace them? Replace the faulty one, reset the ecu, continue driving the car. the o2 are not hard to get to at all and takes about 20 min to change one.
Save the money and wait till it goes, then change it.
Old Dec 14, 2006 | 08:10 PM
NCSUpilot's Avatar
Thanks for the response...I think I might just go ahead and replace the faulty one and see if that helps...
Good call on the Wolfpack!
Old Dec 14, 2006 | 09:00 PM
matrix11229's Avatar
Replace all 3 sensors. If one failed, the rest are on their way (and you have a 95 which is not so new). I bought all 3 and saved on shipping.
Here is the link to the seller I bought from (highly recommended):
http://search.stores.ebay.com/GLOBAL...271212QQsofpZ0
Old Dec 15, 2006 | 02:23 PM
dr-rjp's Avatar
If you choose to do all three, I have a used set for sale (all with less than 36k)
Old Dec 16, 2006 | 11:09 AM
i30ds's Avatar
Armed and Dangerous
What ever you do... DO NOT buy used O2s as offered above.
Old Dec 16, 2006 | 11:11 AM
i30ds's Avatar
Armed and Dangerous
98 rear O2 is incompatable with 95 vehicle.
Old Dec 16, 2006 | 04:25 PM
jsidhu's Avatar
there's a fuse inside the car for the O2 heater. Make sure its not blown..
bbsitum
Sep 6, 2019 07:31 PM
220k+ A32
Sep 11, 2015 02:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
