Low rpms, Stalling
Old Dec 15, 2006 | 07:44 PM
JUDE's Avatar
Low rpms, Stalling
I'm having issues where the rpm's are going way below one and the car stalls. Sometimes I might be going 40-45 and if I hold the clutch too long the car will stall.
If the AC is on, it never stalls. Any ideas?
Old Dec 15, 2006 | 08:54 PM
madisonmxma's Avatar
a problem with the idle air control sounds like
Old Dec 15, 2006 | 09:24 PM
JUDE's Avatar
Easy fix? Where is it located?
Old Dec 15, 2006 | 09:54 PM
yah its easy. its located on the throttle body. it has three connectors on it
Old Dec 16, 2006 | 04:16 PM
XAugusta MoonX's Avatar
Haha everyone seems to be having this problem. But yeah, IACV check the stickies for more detailed info and then go out and buy some brake cleaner or something (I can't remember) and clean that sucker out. You'll be good to go.
Old Dec 16, 2006 | 04:17 PM
jsidhu's Avatar
it would be a good idea to clean the throttle body while ur at it.
Old Dec 16, 2006 | 07:22 PM
Mishmosh's Avatar
Yeah, clean throttle body, check and adjust for accurate base idle (ie. throttle pos. sensor disconnected). Check all rubber hoses connected to the intake manifold to make sure you do not have a vacuum leak. In my experience, just cleaning the iacv doesn't do a whole lot.
Old Dec 16, 2006 | 07:47 PM
OC guy's Avatar
2002 maxima se
IACV= ignition air control valve? if yes then is it easy to clean that part on 2k1 max or do we just replace it and what about TPS does that throw any code when goes bad?
Old Dec 16, 2006 | 08:25 PM
gtr_rider's Avatar
192.168.1.1
Idle air control valve needs some cleaning
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
