Crank Position sensor troubles
Old Dec 24, 2006 | 10:06 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
Ok its christmas eve so i dont expect lots of quick answers but as good as i am with cars im stumped and need help. Heres the senario :
Car drives fine all day and park it at night but the cel is on for P1336
Next day i go to drive it and at 3000rpm it stutters and loses power ect...
CODE P1336 comes up for the CPS (POS) rear crank sensor.
I replace the sensor and still the same outcome.
i used an ohm meter on the new and old sensor and they had the same reading. There is 3 pins on the sensor so there would we three ohm readings.
165,154, and 21 for (ex pins 1&2, 1&3, 2&3)
the new sensor read the same ohm readings so i concluded its not the sensor. Maybe the harness ? i used the ohm reading on the pins thru the harness and got the same ohm readings BUT :
the harness has 4 pins on one side and 3 on the other...am i missing something ? what else would cause the P1336 code ? where does that other wire go ?
im pretty sure the plate on the back of the flywheel wasnt damaged cause the car was riding fine before.
im just fishin for some answers before i take it apart again......im so sick of removing that tranny.......i may just trade it in crashed and all and get a new car....
Old Dec 24, 2006 | 07:08 PM
YoU CaNt SeE mE
bump for christmas...
Old Dec 25, 2006 | 12:21 AM
WielkiWaac's Avatar
MaximaDriver
download service manual for testing procedure.
maybe ho have bad connector or tooth on timing plate is damage
Old Dec 25, 2006 | 06:47 AM
2DMax's Avatar
Stupid question, but did you clear the ECU after replacing the sensor?
Old Dec 25, 2006 | 07:46 AM
YoU CaNt SeE mE
tried downloading the FSM but i keep getting an error. any change you can email it to me ? tearsanddreams@comcast.net
I had it on my other computer but it crashed.
yea i have a scanner that i reset my computer with.
if anyone has the FSM it would help greatly. thanks !
Old Dec 25, 2006 | 11:28 AM
njmaxseltd's Avatar
P1336 - CPS (POS looking at the flywheel from under the bell housing)
Sensor signal fault or signal plate damage.
If you changed the correct sensor and the code still comes up, then your next step is to check the signal plate (Flywheel) for damage.
The flywheel has 6 specific pickup points.
Merry x-mass.
Old Dec 25, 2006 | 11:32 AM
YoU CaNt SeE mE
dam i figured it wouldnt be something easy......all well...back apart the car comes.......
ANYONE have a signal plate for a manual tranny ????
mvm062
Nov 30, 2020 09:00 AM
James92SE
Oct 8, 2015 04:57 PM
gustavison
Oct 4, 2015 06:50 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
conansriver
Sep 11, 2015 10:26 AM
