Noise when turning steering wheel
Old Dec 25, 2006 | 08:51 PM
QBridge's Avatar
I have a 97. When its really cold out and I turn the wheel left and right without the car moving there is a knocking noise coming from under the hood. The car had both the drive shafts replaced months ago and the wheel bearings on the front so its not the cv joints making the noise or the bearings. There is also some steering wheel play and I turn the steering wheel like half an inch both ways and the wheels wont turn. The power steering fluid is old and I will change it but that doesnt explain the knocking noise. After the car warms up or if its warm out there is no kocking. Anyone know what I need to replace to stop the knocking?
And does anyone know a place online that sells rear wheel bearings? I tried partsamerica and ebay.
Old Dec 26, 2006 | 07:07 AM
triumphD6's Avatar
did you check the tie rod ends and any bushings when you were doing the axles and bearings? Could be them.
Old Dec 26, 2006 | 09:25 AM
dgeesaman's Avatar
Maintenance Monster
The fact that it only happens when the car is cold suggests a power steering issue. Is it filled with fluid? Might it need to be bled?
Old Dec 26, 2006 | 11:02 AM
QBridge's Avatar
I did not check them and I know they are old. I actually need to replace any and all bushings on the front and it needs an alignment.
Does anyone know why I have steering wheel play? Is that caused by the bushings? It had the play for a few years actually.
Old Dec 26, 2006 | 12:50 PM
triumphD6's Avatar
steering wheel play when not moving is ussually tie rod ends, although it could be caused by worn bushings. I'd start with the tie rod end though.
Old Dec 26, 2006 | 01:04 PM
NotoriousMAX's Avatar
You may need to replace or regrease your strut bearings...and try nissanparts.org for the rear hub/bearing assembly as you will not find just the bearing. If you want to know whether you need new tie rod ends jack up the front end and shake the tire from side to side and if you feel play then you do need them.
Old Dec 26, 2006 | 03:07 PM
njmaxseltd's Avatar
Originally Posted by NotoriousMAX
You may need to replace or regrease your strut bearings....
They always act up when it gets cold outside. Mine does it as well, I just ignore it all winter long.
Old Dec 26, 2006 | 09:41 PM
QBridge's Avatar
Im a lilttle confused. How many inner and outer tie rod ends does a car need. Isnt there one of each for each side/wheel? partsamerica sells 2 outer and 2 inner.
And I found strut mounts on nissanparts.org not bearings. They sell the struts though. Which do I need? The struts or strut mounts.
Im not really good with this suspension stuff because I never had to work on it before. Is there anyone making solid racing bushing for this car?
Old Dec 27, 2006 | 02:37 AM
Sloppy Snood's Avatar
This should help:
Energy Suspension (ES) Polyurethane Bushings:
Source: Suspension Restoration Parts Co.
Front Control Arm Bushings (ES 7.3111) $35
Lower Sub-Frame Bushings (ES 7.116) $23
Front Sway Bar Frame Bushing Set (ES 7.5118 (20mm)) $7.00
Front Swaybar Endlink Grommets (ES 4803-G; 4 required; $1.00 each) $4.00 Total
Optional:
Motor Mount Insert 1995 -2003 (ES 7.1114) $80.00 2 large bushings. Replaces the OEM frt. & rear subframe mounts.
Will not fit cars with Automatic Transmission
McQuay-Norris Ball Joints and Tie Rod Ends:
Lower Ball Joint (FA 2176) $28.00 each (2 required for rebuild) $54 total
Outer Tie Rod End (ES-3438) $24.00 each (2 required for rebuild) $48 total
Inner Tie Rod and Boot:
Sources: InfinitiPartsUSA.com (Infiniti of Scottsdale, AZ) for $42.94 and $27.48
OR Pinnacle Nissan for $44.08 and $28.21
OR Midway Nissan for $42.94 and $27.48
OEM Nissan Inner Tie Rod (Nissan part: To be Determined) $42.94 (1 required for rebuild) $42.94 total
OEM Nissan Inner Tie Rod Boot (Nissan part: To be Determined) $27.48 (1 "required" for rebuild) $27.48 total
OEM Nissan Wheel Bearings:
Sources: InfinitiPartsUSA.com (Infiniti of Scottsdale, AZ) for $42.50
OR Pinnacle Nissan for $43.64
OR Midway Nissan for $42.50
OEM Nissan Wheel Bearings (Nissan part: 40210-30R01; Nissan part name: Bearing Assy-FR) $42.50 each (requires 2) $85 total
OEM Nissan Inner & Outer Grease Seals (Nissan part: 40232-33P55; Nissan part name: Seal Hub) $10.50 each (requires 4) $42 total
OEM Nissan Strut Bearings:
Sources: Courtesy Nissan for $30
OR Pinnacle Nissan for $26.40
OR Midway Nissan for (price not listed)
OEM Nissan Front Strut Bearings (Nissan part: 54325-5V000) $26.40 each (requires 1 set) $26.40 total
Old Dec 27, 2006 | 08:42 AM
QBridge's Avatar
I appreciate it. Thank you.
trasmadean
Feb 1, 2017 08:20 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
official_style
Aug 29, 2015 10:10 AM
tnewbs
Aug 28, 2015 10:15 AM
jhontelj
Aug 17, 2015 04:07 AM
