Clutch Recommendations
Old Dec 31, 2006 | 07:34 AM
toddemullins's Avatar
Those who have experience with aftermarket and OEM clutches please chime in....
I have a 99 SE with some mods (00VI, CAI, Y, cat back, custom traction bars, etc.) and if all goes well, a 75 shot in the spring. I need a clutch now and can't decide between the 5th gen clutch or Spec Stage II or similar aftermarket clutches. Problem is... OEM specs measure pressure plate clamping force in lbs. (1400 and some change to be exact) and aftermarket clutches measure in ft/lbs. of holding power. Maybe someone has an idea how to compare?
I've heard that the 5th gen clutch is made by Exedy and is the same as the Exedy Stage I. Any truth to that?
There is a difference I see is cost at this point. The 5th gen can be purchased for just at or near $200 when most aftermarket are in the $300 range.
I just don't want to purchase the 5th gen, spend the hours installing, and then find that it won't hold at the track with the power.
Suggestions please.
Old Dec 31, 2006 | 07:39 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
there is guys here running 10 plus lbs of boost on an exedy stage one. your little 75 shot wont even budge it. ive got a stage one on mine with the same mods maybe a few more.
Old Dec 31, 2006 | 07:41 AM
MDeezy's Avatar
I would be good to decide wheather or not you will run the 75 shot in the spring. That is going to make a difference. the 5th gen clutch will perform well, with your current setup, but result will vary when you add the 75 shot.
A Spec Stage II would be more than enough for your current setup, and would be able to handle the 75 shot. As it is now, the spec would be overkill.
in redards to exedy making our oem clutches, I heard something to that nature but cant offer a definate answer.
If you plan on spraying a lot, and going to the track a good amount of times, might want to setup up the clutch so it can handle the abuse it will get.
Old Dec 31, 2006 | 08:28 AM
MDeezy's Avatar
http://forums.maxima.org/showthread.php?t=495880
this might help to give you an idea.
Old Dec 31, 2006 | 10:59 AM
Thanks MDeezy, I read that post a while back. From all my reading, the 5th gen is great for a DD, but not great for track use. I guess I'm looking for a good combination clutch for an hard driven DD that sees the track a few times a year.
Old Dec 31, 2006 | 11:01 AM
Can anyone confirm that the OEM 5th gen is made by Exedy?
Old Dec 31, 2006 | 11:11 AM
southeast_first's Avatar
my 5th gen clutch was made by valeo.
user 11122324
42
Jul 18, 2022 03:35 PM
MaxLvr21
Oct 17, 2015 12:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
carlosvq30
Sep 26, 2015 09:44 AM
sdotcarter
Sep 2, 2015 09:53 PM
