help no power getting to starter
Old Dec 31, 2006 | 01:02 PM
euromaxima's Avatar
help no power getting to starter could it be factory alarm related
my ignition is getting power but im not getting power to the starter, does anyone have a wire diagram to where the wires run from the ignition to the starter? I can use a jumper wire and start the car that way but when i use a test light it im not getting power. I pulled the factory alarm fuse cause my key fob wont stop the alrarm form beeping. could the alarm disable the starter? thanks
Brandon
Old Dec 31, 2006 | 03:52 PM
njmaxseltd's Avatar
Most likely it's the ignition switch, a common failure item in our cars.
Check all the fuses and make sure you don't have a relay gone bad.
For $15 bucks the Haynes shop manual has complete wiring diagrams to help you troubleshoot.
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
maxima297
Sep 30, 2015 03:32 PM
